- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,483
- Reaction score
- 8,555
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
Sounds like you have a valid fix, If I had a picture, I could probably determine exactly what the (Positive) Wire grounded to mount goes to. --- This is a Short to Ground
Being that the Tech stated (Network) , he may be stating a (Positive) Com feed
But as far as Power to the BCM - It would be (1) of 2 wires feeding the BCM, to tell BCM the Key-In and Key-Position, once this information is received by the BCM, it then allows the Ground on the Run/Start Relay
Either way, I'm glad they finally found it
Now, sit back and relax and enjoy the Ranger
You had it there in the column with the switch.
