Tremor question
gwhalin
Greg
New York
They have gotten worse and worse about mounting that relay box from looking at yours. It has always been pretty shoddy with a lot of tape holding it in place though. No idea on the park aid error?
Mike47532
Mike47532
Ferdinand
2023 ford ranger xlt tremor
Thinking it’s a bad sensor and yeah that box not being mounted is sad and paying that much for a new truck and finding out they can’t make sure everything is mounted right is a bunch of crap
Danager
Dan
Alberta
2019 Edge
Manager
If the truck was recently washed, there may be ice on one of the parking sensors.
As for the relay box, it should be mounted. Not normal to just be hanging/sitting there.
Highlander
Frank
Nova Scotia, Canada
Private
LB'sTremor
Loren
Tampa
22 Iconic Lariat Tremor
IT
Well I am sure they will fix it. And Welcome to the Forum and moneytrain first stop Damperville... Great looking truck! Hot Pepper red
LB
bRaptor
Ward
USA
2021 Ranger XLT tremor
This is true. Your relay should not look like this. I also get that warning in colder weather, but since you need to get the relay looked at, you might as well ask while you're there.
JasonTremor
2021 Ranger Tremor XLT
My 2021 XLT Tremor aux box was taped up as well. I just removed tape and clipped it on it's mount. Took about 30 seconds.
MXGOLF
Sales / Photographer
It must be budget cuts. LOL Add it to the list.
Jhbryaniv
2023 Ranger Tremor
I feel like mine bounces out on occasion.
It really is not a solid mounting solution - mine only clips in on one side.
I might just figure out how to use a self taping screw and mount that bigger so it doesn't come out again.
JasonTremor
There are two clip/release points on my mount bracket. They are part of same mount and the fuse box slides vertically down. It isn't the most solid mount, but gravity keeps it in place once clipped in.
Bsthroop
Brian
New Mexico
2019 Lariat 4x2 Sport
Broadband/ Microwave Engineer
Just recently purchased a new 2023 ford ranger xlt tremor already got an error message check park aid? Plus the Aux switch’s box under the hood is not mounted is that normal?
Love that color!
HMG03
Calvin
New York
2021 Ford Ranger Tremor, 05/06 ZX6R 636 Stunt Bike
Firefighter
When I took delivery of my Tremor my box was hanging just like that too. I just took the tape off and clipped it into the thing that was there and done.
Hi Mark,
Unlikely budget cuts as the correct clips are still present. It is more likely that the line operator has too many things to do as the Ranger moves down the Assembly line. Not sure how it is processed but likely trim line. Operator tasks are changed from time to time and the Plant assembly engineers guessed wrong on operator time. Reason I say this is that there are several posts on this being taped and it was not on units built the same day, ie a relief operator as the real operator takes a bathroom break for example. Surprised a plant audit did not catch this one.
