Trailer Tow Package Does Contain 4 Wires for Aftermarket Brake Controller Install
rangerdanger
SF Bay Area
t4thfavor
Chance
So to tap the break signal, I'm guessing with all the wizardry going on with the collision avoidance and whatnot, it's not as easy as vampiring the signal from the top of the brake pedal?
heathconder
heath
kentucky
2019 ford ranger xlt supercrew 4x4
that's a good question ill find out when I install and test it.
Geoff
NYS
'19 Ranger 1943 Willys Jeep
Retired Engineer
I would think you can find the Brake ON/Off Switch mounted near the Brake pedal. That switch turns the brake lights on an off and I see no reason why tapping into it for the brake controller would screw up anything....
BTW, as an aside, that switch also fed into my cruise control on my '02 Ranger and when the switch got flaky the Cruise control didn't always engage.
Edit, it looks like Fuse 64 (owners manual pg 237) feeds the Yellow wire - did you by any chance test that?
t4thfavor
Chance
What I mean is the adaptive cruise, and the brake assist is turning on and off the brakes without input from the pedal, I'd hate to see the brake assist attempt some braking maneuver without letting the trailer know it's about to go down. I don't think the brake switch "knows" when the brakes are on unless it's the driver doing the braking via the pedal.
Geoff
NYS
Retired Engineer
Adaptive cruise braking turns on the brake lights so as long as you tap into the brake light signal I see no issues. The brake pedal itself may not be initiating the braking but I suspect the output of that brake pedal switch is going on and off with the brake lights regardless on what initiates braking (this would be a "wired Or" situation). If not, then the actual brake light signal needs to be tapped into.
t4thfavor
Chance
Yup, that's what I meant. I guess we won't know until someone brave taps the pedal and drives around with a test light hooked up.
Geoff
NYS
Retired Engineer
I still can't believe Ford hasn't documented this in some form or fashion that doesn't require buying the wiring diagrams.
They need to issue a TSB on this.
Geoff
NYS
Retired Engineer
Yes, proving that would be a good idea.
heathconder
heath
kentucky
ill check that tomorrow and let you know what I find out.
FLEngineer
Orlando,FL
2019 Ford Ranger Lariat SCrew
Wiring diagrams attached...
Geoff
NYS
Retired Engineer
Good stuff FLEngineer.
If those are the current diagrams for the Ranger the colors are different that what heathconder found.
Page 4 shows:
  • The Yellow wire going to fuse 64 which is what the manual shows for trailer brakes (pg 237) - Consistent with what heathconder found.
  • The Brake ON/Off switch (BOO) wire which has not been found yet is Violet with a White Stripe
  • The output of the brake controller feeds a Blue wire which we thought was Green with a Black stripe
  • White is ground as heathcondor found.
These wires are near the left side kick panel so perhaps the BOO wire is still hidden and, perhaps, the Trailer brake wire is Green/Black instead of Blue. That is easy enough to ring out.
Progress. Slow but progress!
