TechnicallyReal
Depending what's going on there may be no time for a stage 1 and you're right into stage 2. And as you said yourself, AEB can't guarantee prevention of an impact, so you might end up colliding with something with up to 7500 extra lbs of force that could have at least been partially slowed down or not tried to pass you had its own brakes had a chance to activate.There are two stages to AEB. Stage 1 the dash lights up red and pre-pressurizes the brake system and Stage 2 where the AEB applies the brakes. Granted I didn't specify manually braking prior to Stage 2 so thanks for having me note that. Also Ford makes it very clear that AEB does not guarantee prevention of impact.
AEB is unrelated to trailer sway control which is active even without a brake controller..
One possibility that comes to mind is an animal running across the road. If the animal is large enough to cause AEB to activate, your trailer might try to pass you, and what would have been a simple animal hit could end up so much worse.
There's also the very real possibly of a false alarm or other bugs in the system to consider. I personally have had AEB stage 1 activate when no one was in front of me. Last thing I want is for it to go full stage 2 and end up jackknifing or flipping my trailer for literally no reason at all
I don't think sway control is going to help in an accident. It identifies sway and brakes individual wheels and limits engine power.. but sway is identified by oscillation. Unless sway is what lead to the accident, sway control probably won't be there for you.
AEB is there to act when us mortals cannot. Having a brake controller that doesn't work with AEB can cause an accident to turn out worse than if you had no AEB at all. IMO people should either turn off AEB if their brake controller doesn't work with it, or if leaving it on, make sure to use a brake controller that does work with it (FYI to anyone reading this, the Curt Echo does work with it)
