tough getting in the truck bed with tailgate down
spartan0078
Ontario
2021 Ford Ranger lariat
Railroader
To be honest I would've appreciated a step built into the rear bumper like GM does. I swear new trucks are WAY taller in the back than previous generations were.
It isn't causing me issue yet. But I can see it being an issue later in life when my legs aren't operating properly.
It's it causing me issue yet. But I can see it being an issue later in life when my legs aren't operating properly.
For some of us the future is now! :wink:
OrangeStreak
Southwest
Retired. MTS degree. ANG veteran. 2nd Amendment supporter.
I keep a Step Stool in the Truck just in case I have a short passenger. This could also be used to step onto the tailgate. Poor man's solution ?
dlow206
Derrick
Seattle, WA
2020 Ford Ranger Lariat
I assume your talking about the bolt that holds the bed to the frame. Yeah that one is a real PITA to break loose. Kind of a pain to get back in too. Not a lot of room to work.
Yep, that one. Couldn't break it loose with a normal size 1/2" wrench. Probably need to get a breaker bar.
VAMike
2019 Ranger Lariat SuperCab
I think I used a short breaker bar and an extension on that, one hand on each of the bar, and it was no big deal, but it was a long time ago and I might be misremembering.
HenryMac
Mech. Engineer - Retired
Might as well just grab the side of the bed with both hands and step up on the rear tire, then into the bed.. The rear tires are about the same height as one of those corner bumper steps would be.
I use this method often. It also keeps dirty feet off the bumper. Give it a try.
spartan0078
Ontario
Railroader
@HenryMac that's generally what I do. But I fear for that plastic toprail getting manhandled all the time. You can hear/feel it creaking around under the weight
Langwilliams
Langley
Lorain, Ohio
The bed cover prevents this. But if it's off for something it works.
HenryMac
It's a weighty issue.. :turkey:
dlow206
Derrick
Seattle, WA
Finally got my trekstep installed today. Got a 2 foot breaker bar, did the job getting that bolt loose no problem.
