Too much oil in my 2.3?
Hi Folks,
I had a frustrating experience with checking the oil after an oil change. I could not get an accurate reading. I had to resort to pulling the dip stick wiping clean and reinserting and waiting a day before pulling it out to read. I was half way up the hashmarks. Perfect. I am baffled why the Ranger is so hard to get an accurate reading....
jrbull
dave
florida
2019 ford ranger
construction
I noticed that also. I was waiting for somebody to say it clearly to confirm what I was seeing.
[/QUO
nothing to see here let it go people make some s up
Matsterious
Matt
Houston, TX
2022 Ford Bronco Big Bend 2.7L Mid Package 4.27
Go tell the dealer they overfilled it. Surely they checked oil?
I'm not sure if that was sarcasm lol but i'll respond as if it wasn't. I checked the oil level and it was at an acceptable range :D
CB750F
Qc
Human
This oil thing is so complicated!
Just a question, how many here follow Ford's recommendation for oil change?
How many had a motor issue, when they followed the manual, due to oil?
GitRDone
Andrew
Orlando Fl
2020 XLT
Real estate management
Agree with Phil about residual oil on Ranger dipstick making a warm reading more difficult. Cure is to check oil in morning before firing up, that lets everything (including dipstick) drain to the sump overnight. In the morning you will get a clean reading.
Suggestion to OP: After next full oil change take a reading (overnight cold) and mark dipstick at the oil level observed. Now you have a true reference of where "full" actually falls on the stick.
Dmc
Deb
Oxford pa
2020 ranger
This is happening before oil change due . Also there won't be a problem in the short term. In the long run it will cause seals to break down premature causing $$$ in repair bills .
Dmc
Deb
Oxford pa
2020 ranger
is the seal breakdown a verified problem?
do we know the seal material? is it prone to breakdown with fuels?
or is this just like the 500 mile oil change for break in myth?
Gasoline, also spelled gasolene, also called gas or petrol, mixture of volatile, flammable liquid hydrocarbons derived from petroleum and used as fuel for internal-combustion engines. It is also used as a solvent for oils and fats. That means it breaks down oils and fats . This makes oil less effective. So stop being a hole . Enjoy your repair bills after warranty runs out .
