Tire Pressure... XLT
Ranger3
Dj
New jersey
2020 Ranger Xlt Sport 4x4
Store Mgr
So ..here's a weird one..had my truck for 2 weeks my all terrain tires are at 38psi..but door sticker says 30......thoughts? My sense is I'm GNA lower then to 32.....what's yours at?
Hi Dj,
If these tires are oem...then they should be set to the door label at 30 psi. If they are aftermanket or dealer upgrade...then you need to go to the tire manufacturer's website for directions.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Hi Dj,
So I have Bridgestone dueler rhs 255/65R17 is this the stock tire how do I know?
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
There will be a yellow black and white sticker on your drivers door jam that will tell you the pressures they should be at and it will tell you the size of the tire your truck came with.
Langwilliams
Langley
Lorain, Ohio
I have the same tire an they were over 40 PSI when I took delivery. This was a common thing if you search it. I lowered them to 32....It just didn't feel right going all the way down to 30 but what do I know.
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Cool so ur running them at 32 cold?
Markbe35
Alberta, Canada
2019 Ford Ranger Super Crew
I usually keep mine at 31-32, especially in Spring/Fall when the temperature fluctuates a lot. I don't like it when it cools off one day at the tires end up at 28.
Langwilliams
Langley
Lorain, Ohio
Yep I went with 32 cold....Don't know why but 30 just feels too low. I should try it to see if it rides better.
LoneRNGR
Lubbock, Texas
2020 Ford Ranger XLT
Systems Engineer
It’s 30. The answer is 30.
Tom_C
Virginia, USA
System Admin, Retired
LIsten to Phil.
OEM tires change over the production cycle with availability. But as Phil said, whatever is on there the sticker on the door is factory recommend pressure.
Personally I run mine at 32. I tried a few different pressures and found that to my liking and handling. YMMV
Ranger3
Ranger3
Dj
New jersey
Store Mgr
Thanks I will lower to 32
