Tire Pressure -- 265/70/17 BFG KO2's
On trucks that come stock with LT tires the placard recommends different pressures. 37 LBS
That I was not aware of. As for going up in pressure for towing have you tried staying at 37? I would think it would be a bit more comfortable.
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Emissions testing supplier
I can't imagine running them at 37+ psi either, that's way to much. I run my 265/70/17 Nitto Ridge Grapplers between 30- 32 psi. When airing down I'm usually between 18-22 psi depending on the terrain.... 18 in softer sand and 20-22 in rocks.
On our last trip up to Sedona I forgot to air down because it was a smooth fire road up top. Boy I remembered quickly once we hit the rocky washboards and were bouncing around the cab. lol
Running mine at 38 and they run perfect. In fact, every place I talked to recommended 36-40. My daughter has the 285 version and runs hers at 38 as well as recommended by the shop that installed them.
Strange they all told me the opposite. lol Are yours LT's?
Philb
Philip
Wyoming
Something else to consider is tire temperature. This is something else I keep an eye on when towing or under a load. Here is a quote from Car and Driver.
"How hot does the tire get? Typical tires experience a temperature increase of roughly 50 degrees after running on the highway for a half-hour. If it's a 70-degree day, this suggests a tire temperature of about 120 degrees. If it's a hotter day, or you're driving faster, or you're hauling a heavier load, or your tires don't have the proper air pressures, they could get hotter. To limit these temperatures, some automakers recommend increasing tire pressures for heavier loads or sustained high speeds. "
TylerV76
Tyler
Oxford, Michigan
2019 Ranger FX4
Not all of them are. There are still p rated KO2's out there but not many.
Did not know that.
Well mine are the E load, daughters are C. Ive got the 275’s and shes got the 285’s. I know the calculator I used from tireplus recommended 35psi but everyone Ive talked to kept going recommending 38.
Did not know that.
My honest thought is to run the factory pressure on the placard when on the street. Off road is another story since you want comfort and traction over rocks and things. If you look at the first few posts I have a video posted about off road tire pressure.
HenryMac
Mech. Engineer - Retired
Just as an FYI:
Just saw a new Tremor and here is the recommended PSI for the stock 265-70-17 General Graber AT .
38 PSI Specified for the LT's on our SuperCab
Hounddog409
Tod
Ohio
F150
Mine were installed and set to 40PSI cold, I thought this was too stiff once they got to temp so I lowered them to 36.5 on all four and they seem to run about 40-41 now at hwy speed and it is much more comfortable. I had them rotated about 2-3000 miles after reducing the pressure and no abnormal wear. The people @ discount said tires still look brand new.
You should do the chalk test instead of guessing. Chalk a section of tire tread and drive. The chalk should be gone equally across the treads. Only gone in the middle...pressure to high. Looking for even "wear" of the chalk across the entire tread pattern.
Chalk all 4 tires.....
This will result in the best psi for your vehicle.
MinuteMan
Ca
Fart Can collector
I agree with you. P265/70/17 at 36.5 psi. I bought a really nice chuck/gauge/bleeder and every tire is finally measuring the same on the app. The ride quality is not too sloppy and not too stiff and the noise is gone. No more scrubbing when I corner.
36.5...everybody is doing it...
FeudalCross
West Central Ohio
2020 Ranger XLT Metallic Gray
Sorry to revive this discussion, but I'm new to running over sized tires (Except the L50's I ran on my car back in the day). I had Nitto Terra Grappler G2 285/60R18's put on the Ranger and searched for the recommended tire pressure.
Of course, opinions varied but between someone that claimed they emailed Nitto to ask, and this website:
https://tirepressure.com/nitto-terra-grappler-g2-tire-pressure
I've been running mine at 48 psi. Thoughts? Maybe the earlier suggestion to chalk them would help.
Thanks!
Thanks!
I feel 48 PSI is a little hike that. My suggestion it's to start at 30 PSI and go from there. I run 285 70 17 on my truck and 30 PSI is perfect. Other tires sizes may vary
