The new rangers have a cover/insulator over the high pressure fuel pump.
TJC
Definitely! Don't know why Ford didn't do this with the Rangers from the start.
Yes you do! :LOL:
Cutting corners and using customers as beta testers instead of doing basic research.
It hasn't turned out well for Ford either, with warranty repairs now taking a big chunk of their projected profits.
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
Finally got around to installing mine. It will work with the JCR engine cover, clears it with a mm to spare.
Joranger2023
Ford ranger
Heavy equipment operator
Saw this on Facebook where someone noticed the new rangers have a cover on the high pressure fuel pump. lt supposedly fits the 19-23 and drastically reduced the pump noise. It's made of the same material as the engine cover. Might also p
rotect that area from the famous drip onto the engine.
Ford Part LB3Z9K540B
Looks like it would keep water out of cylinder 4 spark plug
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
My wife’s explorer has one that covers just the pump. Did spark plugs yesterday and it wasn’t in the way at all. Seems flimsy tho. I hear her engine less than mine, but there is probably more interior sound deadening too.
Jason B
Louisiana
2021 XL STX SE 4x2
machinist
The problem with that cover is that you have to make a cut into it to get it over the fuel line, thus possibly defeating the 'water proofing' ability.
See post #34 about the Cover.
Joranger2023
Ford ranger
Show
If you find the pump noise that bad go ahead and do it, if you're worried about water I'd do the JCR cover and rubber edging I did a post on, it works very well.
It's a better solution than adding more mouse food to your engine bay.
can you show me what you did? I have a 2024 model, I did the pipe insulation thing on a 2021
Shax
Brandon
Morgantown, West Virginia, United States
2021 ford ranger XL
I know this is an old thread. It was very helpful and I was able to put the cover over the hpfp. Id say this probably quieted it down by 50%.
As someone previously mentioned it seems like I lot of the noise resonates through the bracket. Could the bracket be removed? Or perhaps rubber washers installed on the bolts?
I suppose one could try and add some rubber washers between the bracket and pump; you would most likely have to spread the bracket apart some.
It's been almost a year since I installed the cover and had that bracket off, I recall it was a tight fit.
How much extra noise reduction will it provide? 🤷‍♂️
The noise never really bothered me, but since I park in a garage, it is notably quieter with the added cover.
Fitzmotor
Gold Sponsor
Saugus
Retired from Honda Racing.
Removing the bracket does reduce the noise a little, I drove around for a while without it, but being a safety item, I was compelled to put it back on, although, I thought if I am in such a bad accident I need the pump protection, I got big problems anyways.
I did put a layer of dense closed cell foam between the bracket and the pump when I put it back on.
Shax
Brandon
2021 ford ranger XL
Thanks for the input! I figured the bracket was just for protection and I completely agree that if your in that bad of an accident that little bracket isn't going to matter. I also figured that with the cover over it now, that adds a layer of protection to it.
Did the added foam between the pump and bracket seem to help any?
Its just unfortunate that the sound is that much of an annoyance to me. So if removing it can help drop the sound more, its completely worth it to me.
Fitzmotor
Gold Sponsor
Saugus
Hard to say what the foam did, I went from no bracket to bracket with foam.
What does not make sense, Ford should be able to either tune out the noise through pump valve timing and bypass relief settings, or with lifter lash and cam lobe profile.
At Honda Racing we used two DI pumps per engine, you can fully tune the noise, as well as lifter lash and closing ramp on the cam, we did it to isolate the mechanical noise so the knock sensors did not pick it up, but it was not a mass produced application, should be similar in some ways I would think.
Actually, the Ford fix is the cover I guess, something simple, cheap!
