Taking to shop for MPG issues; what to check?
jblc
JB
USA
2021 XLT FX2 supercab
short of a thermal camera to see rotor temperature this is the next best
Yeah, actually in the meantime I thought of using my thermal camera as well, so that seems best :)
Just don’t mire yourself into speculation and rhetoric… do something and test it out. Sometimes small changes will result in great results.
Yep, agreed, and thanks for the reminder/encouragement! I'm working my way through a list of things to check from this thread, eg checking plugs, so it'll take some time but there are actionable tests :)
pbethel
Patrick
kingman az
As documented in various threads on the matter, dealers are plenty willing to brush off Blackstone reports.
Yeah, your right.
Just wait until dealer blows him off then he can fire the parts cannon at it.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Hand calculating is useless...needs to be done properly via an app, the dash, a Scan Gauge.
Auto start/stop is not really saving much, and is offset by the lots of extra that's put on the starter.
I cannot state just *how* incorrect this is. I don't know what you understand "hand calculating" as, but it will always be the most accurate calculation you can do assuming you have accurate gas pumps (fill to roughly the same level) and accurate mileage readings (your speedo/odo are correct).
The dash is historically *incredibly* generous, and for most people 1-2mpg off, if not more, from what actually is being achieved. Apps and scan gauges can be afflicted by similar, and different, problems as the dash. Unless they're actually reading fuel pumped into the engine (using fuel flow/etc) and combine it with distance traveled, they're going to be off as well. Even using things like Torque, I've never managed to get any closer to actual mileage than the dash is.
They key to proper mileage is proper measurements (if you change your tire size you need to calibrate your speedo so distance is correct, and make sure you're filling to as close to the same point every time as you can - trying to use the same station/pump if you can, filling to the same point (first click, wait 30s, fill until it clicks again), you'll be less affected by variances here if you usually put in 1/2 tank or more, especially given how little volume actually varies there), and using those, a hand calculation is as accurate as you get (whether it's legit doing the math with a calculator or plugging the values into Fuelly or something, which is the same thing).
Also Auto start/stop isn't offset by starter wear, starters these days are designed for the duty and load cycles of an auto start/stop system, and that wear has no impact on your fuel mileage. They could offset fuel savings if they wear out faster, but that's not historically the case and still isn't a direct impact to MPG.
Yoda say's....
Hard to "hand calculate" when it is only 3 fingers you have.....
Grandaccess
Binghamton, N.Y
Computer Consultant
city/highway or even towing mine seems to hang right around 22mpg
I try and fill up with 92 oct/non-Eth
I use Fuelly app and plug in data from a printed receipt. I go all the way to 3 place decimals. It’s just as accurate as your hand calculator and I verify input by dollar amounts being exact to each other. Now I also have a stored record now of that fillup.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Yup. Fuelly is just fine. I started an excel doc back in like 2006 that I've just used ever since for all my vehicles, since before Fuelly was a thing, but it just does the same math for you without you needing to do any manual stuff. Just give it values and it spits out your result. It's a tool that's perfect for what it needs to be.
I use the FUDFUA method.....
FillUpDriveFillUpAgain
Fool proof and always accurate !!!
Joeiconic
You‘ve kept a gas tracking spreadsheet for 17 years? Is that for business expense reasons?
Dextrose
SoCal
2019 Ranger XL
HealthCare
WOW, that's a great price for fuel! I'm over $5 for premium in Comifornia.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Nope! I use MPG tracking as a way to help budgeting for vehicle upgrades/replacements, as a very basic indicator of potential "non broken" issues with a vehicle as mileage is usually the first hit when something goes awry. It also helped me figure out brands with the "best" mileage potential (usually places like BP, Shell, Costco, and QuikTrip).
Joeiconic
Wow, I don’t even balance my checkbook.
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
Thanks for sharing the amount of gas used in 93K miles...I think I'll just park my truck now...
