- Joined
- Aug 24, 2022
- Threads
- 28
- Messages
- 4,452
- Reaction score
- 8,508
- Location
- Midwest - KS
- Vehicle(s)
- 2022 Ranger Lariat-Super Crew, Cactus Gray
- Occupation
- Aircraft Tech
To be all inclusive of all options for tie ins,
As each (Door Ajar) indication operates the same with separate power feeds.
The grounds for the other doors however have several splices in the circuit so no direct tie in unless you go directly to the individual door, which requires pulling the door panel.
I personally think the Hood Switch is the best spot with a slightly longer wire run than going to one of the doors.
Plus , if you choose to go with only the tailgate ajar and the tailgate is down , you are going to have a Door Ajar message showing when it is down,
Not sure I would want that message on a rear door with young children in the back seat.
I want to also point out, that depending on how well the Reed Switch works on the handle, we may be able to also tie in another switch for the Tonneau Cover or Tool Box Lids.
On paper it should work, but we know the Ranger is a Finicky truck when it comes to adding anything outside of factory .
I have ordered a couple sets of Reeds and some 2 Wire and Single Wire connectors to get started.
The first and most important is going to be placement of the Reed at the handle to actually trigger
