Stock Tremor w/1" wheel spacers - pics
Mostly Harmless
New York
2021 CG Tremor
Updated OP to mention loosening and moving the crashbars seemed to have fixed the rubbing in reverse.
I wanted to update you with some good news. I loosened the bolts on the crash bars and pushed them forward as far as they would go and retightened; seems it gave me all the clearance I needed. Turning the wheel right, full lock in reverse I can hear a TINY touch but only if I am literally holding it to lock which I wouldn't advise doing with any vehicle anyway. Turning left full lock and no rub in reverse.
Before adjusting them going full right in reverse only it would rub enough that I could probably only get 90% of my steering at best. Full left and reverse it would kiss but could get about 99% of my steering.
Never had rub forward in either direction full lock but assume now there is even more clearance. I will probably address this again once I wear out the original Tremor tires and upgrade to 275/70/17.
Thanks for updating me! This is great news.
SEkevin
Kevin
Minnesota
Ford Explorer, 2021 Ranger Tremor Lariat
Healthcare
And here’s what they look like with 1.5” spacers and 285’s and RC flares haha?
What do you have for a lift on your Tremor? Would love to get to 285’s at some point!
Ranger54
Ben
Northwest Arkansas
2020 Ford Ranger Lariat FX4
Service advisor
Mine is an FX4 with tremor grill and wheels. Has the Fx4 shocks with 2.5”RC leveling kit.
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
All that matters is that you like how it looks. I do think however that ford should have gone with a more aggressive offset on the Tremor wheels. The sucked in look is terrible stock.
awd.nv
awd.nv
Anthony
Las Vegas, NV
'21 Ranger XLT Tremor
Computers
Yeah I agree with you. If these really are 100% the Ranger Raptor wheels, the offset looks better on the Raptor with its different suspension,
The 1" wheel spacer looks perfect! Are we still pretty much limited to stock tire size tho (w stock wheels)?
Thanks, I would say without removing the crashbars stock tire is max. I plan on going 275/70/17 when these tires wear out though and either remove the crashbars or install high clearance ones. I would do the good ol' 285/70/17 but I am not sure I want to mess with the gearing much since I tow a travel trailer in windy conditions more often than calm conditions.
McDeuce
2021 Ranger Lariat Tremor
At this moment all I did was remove the plastic trim on the front crash bar.
Lol I noticed that the other day when I went to remote start it. Thought "finally looks like the picture"
Anthony , now that you have the Ranger Lift 1” installed ( by Robby !) … did you gain room ?
TdotReckless
Tyler
Ontario
2019 Ranger XLT - 2022 Ford Ranger Lariat Tremor
off-Topic
off-topic but i love the tailgate cover, where did you buy that?
Great looking truck!
awd.nv
awd.nv
Anthony
Las Vegas, NV
Computers
I did not measure the day of, which I should have but my schedule was so tight I forgot to do that.
Measurements from a previous day were as follows at the center of the wheel well opening
Front 37.25" Rear 38.75"
Today, as parked on the street which would have been the same spot I measured
Front 38.0" Rear 38.75"
Even if it is only 0.75". I am ok with that. Looks good. Could be some front dip from when I parked but I wont be loosing sleep over 0.25"
I went to get it aligned this morning and the shop was having an issue with their sensors once they lifted their rack but baseline numbers were all green except the Caster was 0.3" out of spec in the red.
I will be aligning it at another shop tomorrow morning but I am not too surprised, drives straight. Just want to make sure things are more in the center of where they should be.
My buddy owns a tire shop in CA and he confirmed that the Tremor alignment specs are different than the FX4. He said the main difference was that the Caster calls for the same specs on both sides for the Tremor and FX4 has a different value on the drivers side.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
So what is with the secret? What are the tremor alignment numbers supposed to be?
awd.nv
awd.nv
Anthony
Las Vegas, NV
Computers
Sorry, I posted them in here somewhere, guess another thread.
McDeuce
Hey Anthony .. any rub at all now with the 1” lift ?
awd.nv
awd.nv
Anthony
Las Vegas, NV
Computers
