awd.nv
- First Name
- Anthony
- Joined
- Apr 26, 2021
- Threads
- 30
- Messages
- 1,259
- Reaction score
- 2,373
- Location
- Las Vegas, NV
- Vehicle(s)
- '21 Ranger XLT Tremor
- Occupation
- Computers
- Thread starter
- #1
Hello,
Just thought I would create this for others to possibly find when searching. Just finished installing the FactionFab 1" wheel spacers and I honestly think THIS is what the Tremor should have looked like out of the factory (well, with 1" level kit up front then I think it will be perfect). At this moment the front is stock height for the Tremor.
Wheel rub,turning lock to lock and slow speed there is no rubbing. Clearance is literally probably less than 1/4" so when backing out of my driveway at lock I got some rub. Doing left and right turns on the street zero issues. I suspect if I got on my brakes at full lock it would rub once the suspension dips a little. Love the look though. (edit: Removed the plastic trim on the front crash bars after this post was made, still some rub in reverse at about 90%-100% full lock though) Updated Wheel Rub: I loosened the crash bars, pushed them forward as much as they would freely do and tightened. Seems it took care of the wheel rub. Never had any in forward but reverse and wheel turned right all the way I could only get about 90% of my steering at best, now I can lock the wheel and barely hear it. Oddly reverse and wheel turned to the left I did not have much rub, more like it was just kissing the bar, now it does not touch at all. This was done backing up slowly out of my driveway and up my driveway.
Quality on the FactionFab spacers looked great. Grade 8 studs were installed as well. Super easy install. Only tip I would offer is to clean the brake rotor surface so ensure they go on nice and even.
Stock 2021 Ranger Tremor with 1" FactionFab wheel spacers:
Edit:
Before/After, not from same day but helps show the difference, look at the mud flaps in particular.
1" wheel spacer, 1" level and KO2 285/70/17
Wheel rub,
Edit:
