Spare Tire
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
A slightly smaller spare won't hurt the gears or the axle unless you have a locker or limited-slip. The Gen 5 Ranger locker is electronic so just don't turn it on if the spare is on the rear.
I've not had to use the spare on the Ranger so far but on my old Sport Trac the difference wasn't enough to trip the traction control sensor however the spare did not have a TPMS sensor so that light came on and also it wasn't balanced so I had the tire shop take care of that while it was there.
There is plenty of room for a larger spare, but if you want all 5 tires and wheels the same the issue is will the cable for the spare tire hoist fit through the center hole of another stock rim? I don't know.
Wait - your Stellie is 17"??? I thought they were 16? Now it's almost 10:00 PM and I gotta go look. Damn it.
It's 6:00 am and no response. Guess Greg fell asleep while crawling under his truck. :giggle:
Yes, it's a 17" steelie.
Rammstein
Stan
Four Corners
2021 Ranger XL, FX4
Outdoor Recreation Planner
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
The factory spare has a center bore of 93.1mm, which is the smallest center bore that fits our wheel hub, and the cable end should fit any rim with 93.1mm or larger center bore.
That's common with most vehicles that factory rims are hubcentric, and the cable end is always slightly smaller. It's generally a safe bet the spare hanger will accommodate any rim you can fit on the truck, prohibited only by over-sized tires.
VAMike
2019 Ranger Lariat SuperCab
IIRC, it depends on which primary tires your truck came with.
JACKSMYDOG
Jay
Ontario
My spare steelie is a 17, my factory wheels are black pack 18s with FX4 package so Hankook Dynapro AT/M.
GTGallop
Greg
Anthem, AZ
www.qrz.com
Program Manager
olyeller
Greg
Camano Island WA
2021 Lariat Crew Cab 4WD FX4, 2019 Challenger R/T
I had a tire failure on my 2021 Lariat FX4 on the freeway which destroyed the tire (at only 2500 miles). It came with Hancook 265/60/R18 tires. I was disappointed to see the spare was 17”. I drove to the dealer as no one else had a matching tire at any tire store. The dealer ordered one at $268. Wow! Tires are getting expensive. They installed it a few days later. After driving around a week or so I noticed the replaced tire didn’t have the raised white lettering as the others. A return trip to the dealers and they ordered the correct tire and replaced it at no cost to me. A couple of days later, I opened my topper and there in the bed was the week old incorrect tire. I’m thinking if I can locate a steelie wheel in 18” size, I could have the correct and (almost) matching spare. I’m going to see if Les Schab can get me one.
Ray_kayak_guy
Ray
Palisades NY
2020 Ranger FX4
I posted a new thread but realized this was here. My question is why? Why put 18's on all four and a 17 spare?
There's something about Ranger's wheel sensors that doesn't play well with different sized tires...one time, I had a leak in one of my 285s so I replaced it with the spare 265 and the warnings went crazy after a few miles...
JACKSMYDOG
Jay
Ontario
Smaller is cheaper?
Most of the Rangers with 17" rims have 16" spares.
That is most likely due to the tire diameter, not the rim size. If one tire is more than ~.5" off from the rest, it will set off ABS and other warnings.
That's true. Some manufacturers use the wheel speed to detect a soft tire. I believe BMW is one.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Yep mine came with a 17" steelie with 265/65 17 tyre which matches the rest of the truck which is also 265/65 but in alloy. I just bought an as new matching alloy from someone on Gumtree for practically nothing, put on a new tyre, and now have a fully functional matching spare. I did notice the centre in the steelie wasn't particularly thick - maybe the spares are lightweight. I'd have to look at an XL specced truck to see what a standard steelie looks like.
bsr956
Brian
Lenoir, NC
2020 Ranger XLT 4X4; 2013 Nissan Altima
My XLT came with chrome wheels on 255/65R17 Bridgestone, spare is a steel 255/70R16 Hankook. Both tires are 30.1" so I should be good. I went to check the spare pressure before my last vacation, had not paid attention to the stem mounted up. Tire had just under 20lbs. While I had the spare down figured might as well get it balanced since it didn't have any weights at all. Mounted the spare with the stem down
