jblc
Which relearn device did you get? Or which one do others prefer?I like this a lot - it’s the right way to do it. A bit more money, but oh well.
Wheel - $250
Tire - $250
Sensor - $50
Relearn Device - $50
Wheel - $250
Tire - $250
Sensor - $50
Here's the stock measurements..Have not physically measured it,but add whatever width you new tire is wider than stock,to the what is currently under your truck.I pull mine out from under when playing off-road.
‘You really don’t want to be trying to get it out from under there when you need it,as it never seems to be in a convenient spot when you do...or it gets in the way clearance wise or damaged on a rock etc making it useless.
I’m not sure which one I’ll get. I’ll ask my tire shop guys what they prefer when I get the wheel, tire and sensor. I’ll also search the threads here to see what others are using. Amazon has them starting at $15 but I’m sceptical.Which relearn device did you get? Or which one do others prefer?
My plan will be to have it mounted to the top of my bed rack once I get one. I don’t plan on doing much right this second with out the proper equipment. The bed rack will be a nice addition!Have not physically measured it,but add whatever width you new tire is wider than stock,to the what is currently under your truck.I pull mine out from under when playing off-road.
