Rub?
NurseNeil
Neil
Winston-Salem,NC
2020 Ranger XLT, SPORT
Nurse
So got my 265/70/17 general grabbers and this is happening. Removed that little piece if plastic on driver's side and it still has slight rub. So basically try to unbolt that piece and cut to pull out? What does anyone know about that fabtech kit to replace and give more clearance? Help!?
NurseNeil
NurseNeil
Neil
Winston-Salem,NC
Nurse
Also I have 1.5 spacers on should I take them off?
Stangman570
Florida Panhandle
2019 Ford Ranger 4x4 XLT Sport
Just loosen the two bolts, shove the bar as far as it will go towards the front bumper. Tighten the bolts and this should give you a little more clearance. However, you will rub with the bars in place if you take this off road or flex the suspension. Take them off or up grade would be the best solution.
NurseNeil
NurseNeil
Neil
Winston-Salem,NC
Nurse
It won't make clearance worse by putting more bar out there?
litalien26
Carl
Valleyfield, Qc
Ford Ranger FX4 2020 / Ford Galaxie 1968
Peace officer
I have the BDS on mine with original fx4 tire for winter..(265/65R17) Normally with 285/70R17 with no rubbing except at full full flex..?
NurseNeil
NurseNeil
Neil
Winston-Salem,NC
Nurse
I see what you mean forward
litalien26
Carl
Valleyfield, Qc
Peace officer
litalien26
Carl
Valleyfield, Qc
Peace officer
any specific type of place install them... ford, tire shop etc?
It's pretty simple if you cut the stock one, you don't have to remove the front bumper to replace them. So a lot of shop can do it(But tell them right away that you don't want to keep the old one so they can cut them...or it's a long job other way). Even you at home if you have tools... there's is 3 or 4 others brands that make smaller intrusion beams..so you can look online for the one you prefer.
NurseNeil
NurseNeil
Neil
Winston-Salem,NC
Nurse
I see whatnyou mean, cut old slide in new...thanks. going to try to loosen first and readjust then the others
Joeiconic
Yes, you are likely rubbing because of the spacers. Many others have those tires in that size with no rubbing. So, either lose the spacers or lose the crash bars, your choice.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Hey Neal
I thought the offset on your wheels was Same as stock, just a little wider (0.5?). You might also try w/o the spacers.
NurseNeil
NurseNeil
Neil
Winston-Salem,NC
Nurse
Hey Neal
I thought the offset on your wheels was Same as stock, just a little wider (0.5?). You might also trying w/o the spacers
Yeah offset is stock, looks like bye bye 1.5 Spacers may seap out for 1 inch..
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
Buy the Fabtech kit. I have it and it’s alot higher quality than the others. It’s pricey but you get what you pay for in this situation
