Rotors
billybos
William
New York
Ranger
plumber
What’s up have 50,000 miles on the ranger and I need to change my rear brake pads. Question is do I have to change the rotors. To me I would say no but some people say the rotors do not last as long as they used to I do not see any visual problems other then normal wear I would just like to get some of you guys opinion
specialKody
Kody
Seattle, WA
2021 Ford Ranger XLT FX4
Software Engineer
The best way to know is measure. You can find the service instructions on this forum, they will provide rotor specifications.
Mustang2Ranger
Garrett
Southern California
Would only replace rotors if out of tolerance (unlikely at 50k), deep gouges, pulsing, hot spots. Not just because of a pad change
Save yourself the money, it does not "need" to be done. If you experience something like the above, by all means
While to do it right can have some shortcuts implemented if using the old rotors, it mainly depends on if you were having (pulsating pedal) issues or vibration issues when braking.
The decision is based on what does the rotor surface look like and what do the off pads look like
If there are any indications of (Hot Spots) or (Cracks) replace the rotors
Don't just slap on the new pads and call it good:
Take the extra steps - remove the rotor and scuff it up - take the glaze off of it. I personally use the (Yellow -Roloc) Disc - it's great for rotors and do not forget to clean the rotor hat and hub surfaces and of course clean and lube the caliper guide pins
Keynote: As this is the Rear Pads, you should be aware that the rear calipers have the parking brake pistons and they do not compress in, they screw in with a special winding tool and there are a number of threads on how to do it on here.
Note that pads are side specific - which is detailed in that thread, I would have to locate it
If you wanted to take an extra step - you could use a hand mic around the rotor to ensure you are in specs for DVT (Disc Variation Thickness)
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
Just my FYI regarding my experience with the rear brakes...
Fun at 7000 miles...
Two years later...
Willier
Will
New Jersey
2019 Ford Ranger Lariat
Logistics consulting
My left inner pad died and ripped up the rotor as well..Irellaced all 4 corners with R1 Concepts Front and Rear Brake Kit, Drilled Slotted Brake Rotors| Optimum OEP Brake Pads
