JimInAllen
- Thread starter
- #1
Not one, but two tires....happy days.
OK.. So you got to explain how you Macgyver'd that one.lost brake pressure on the truck.
a rock crushed and split the brake line. fixed it temporarily with a golf tee.
Awesome! Time to upgrade!Not one, but two tires....happy days.
Nice fix. ? It would never have occurred to use a golf tee.i cut the line off flush
jammed the gold tee into it, then did two folds of the line.
the folds greatly reduce the pressure the golf tee had to hold back.
i filled with borrowed brake fluid and it held up
Always keep a small set of vice grips in the glove box. On more than one occasion cut, crimped and folded broken or leaking brake lines that were toast. Off roading 101 hacksi cut the line off flush
jammed the golf tee into it, then did two folds of the line.
What luck... finding a golf tee in the gas fields of Alberta !!thats sucks.
reminds me of one trip i had to do into the gas fields of Alberta...
Rental Dodge Ram, and a tent trailer.
got a flat on the trailer. put on the spare.
drove a bit and the lugs came loose. tightened again and drive a few more km.
got another flat.
left the trailer and continued to camp.
headed back to town the next day to fix the trailer tires (all three, spare included). and get the brake line fixed on the truck
found broken studs on 3 wheels. one had two gone.
got tires fixed. got truck fixed. headed back to get trailer and get it into camp.
Had another brake failure on the way. same issue......fucking Dodge shit.
If you know what/when/where etc, it may be worth a call to the police, and local Roads Department to check for info on what may have led to this. Lots of possibilities that may come with "at fault" of someone else, and help off-set your costs.Not one, but two tires....happy days.
