Redarc Tow Pro Elite Install
Long Island, NY
2019 Ranger Lariat FX4 Magnetic, 2015 BMW 435i GCM
THANK YOU SO MUCH! YOU ARE THE MAN! I've used your excellent wiring instructions to install a Takonsha Prodigy P2, it works like a champ. Happy Trailering!
GrayGen
Bowling Green, Kentucky
Received Ranger September 19th. Hot Pepper Red Lariat 4x2. Locking rear axle 501 package Spray bedliner Bed extender & more
Looks like the AU pics circulating around... clean install
Note the wires have blue painter's tape holding them to the larger harness. Apparantly only on the newer models. Mine was built Aug 30 2019. Makes it very easy to find. See post 80 pic 1
DrRoger
Roger
Dallas, TX
2011 Taurus, 2019 Ranger XL (May 20)
Completed my install late last week. Thanks to all who came before me..... Most helpful!
It was a pain in the butt to work on the footwell and my wiring harness had very little slack. But, successful install and everything is working perfectly!
Several of us have previously commented on the lack of slack in those wires. Ford could have given us another inch or two.
woodzy
2019 Ranger Lariat, 2013 Ford Tauraus
Finally got my redarc brake controller to work, has excellent performance, very happy with it
Can you tell us how you managed to get this working - It looked like you had a lot of issues getting it to work. Maybe it will help other people that may have an issue if they try to install theirs.
srgredranger
Scott
Lawton,Oklahoma
Setup tech / Goodyear
I made all connections at left kick panel except black/green stripe ( blue on some ) I didn’t use. I ran blue wire from Redarc controller straight to the back and spliced the wire to blue wire on 7 way plug . It works great and have towed over 400 miles with it working every time . The instructions for Redarc say to run their Blue wire straight to back and connect to Blue ( trailer brakes ) wire on 7 way plug . I know the truck has automatic braking system but I didn’t have any problems with brakes. I bought my truck end of February and Ford still has no brake controller for this truck which leaves the buyer to install an after market controller to tow a trailer . I bought my truck to tow my travel trailer ( R-pod 178 ) max weight 3900lbs . Ford should have had everything in place before production and advertising 7500lbs when properly equipped towing ability. Some people may disagree with me and that is fine.
Fawnbuster
Indiana
Retired 34 years as LEO
I'm coming up on about a month of ownership with my Ranger and I love it. 7,500lb towing capacity is great but in most states you won't be able to tow anything past 1,500lbs (legally). A big mis-step by Ford is not offering or including a trailer brake controller at launch, and at the very least the uncertainty and/or mis-information by salesman, parts and service staff, vendors, etc. The install was in my opinion very easy and straight forward and could be installed by someone with basic electrical skills. Took me a little over an hour from start to finish, including replacing the fascia below the radio. I'm hoping that this post might help anyone that might be considering going after market or may be a little hesitant in installing a brake controller themselves.
I decided to go with the Redarc Tow Pro Elite https://www.etrailer.com/Brake-Controller/Redarc/331-EBRH-ACCV2.html ($202.10) because of it's small foot print and ease of install. I'm a pretty stocky guy and downgrading to a mid-size truck, I was concerned with constantly banging my knees on a brake controller module or having it rattle around over time on off-road trails. The Redarc module can be tucked away and mounted in any position and the remote module is very small and can be easily mounted anywhere with a few inches of clearance. While I thought that I would miss a screen readout of the braking status, the times I've been in vehicles with the Tow Pro Elite, the feedback from the color changing LED from the remote gives just the same amount of information as my old controller but in a much simpler way. We also regularly tow an off-road tear drop trailer so having that second user control mode where the trailer does not brake proportionally when the truck brakes that I can control manually and independently on the trailer is handy off-road, especially during steeper descents or climbs when I'm trying to maintain inertia of my truck but need to brake the trailer.
I originally intended to mount the remote controller in the center console right below the Trail Control knob. This is also where Ford installed their Redac brake controllers on their Ranger tow vehicles at pre-release media and sneak-peak events. I would have preferred some place higher on the dash within eye level but I didn't think there that had enough rear clearance for it. I didn't really like the idea of having to look that far down while towing to get visual feedback, so I ended up ordering a Lightforce fascia kit from Australia for their Rangers hoping that it would fit, prepared to mount it in the center console if it didn't. Luckily it fit like a glove and the details to it were posted here:
https://www.ranger5g.com/forum/threads/lightforce-switch-faschia.1908/
Here's a link for the Redarc Pro Elite's instruction manual:
https://www.redarc.com.au/Content/Images/uploaded/Manuals/EBRH-ACCV2 Instruction Manual.pdf
Ford Service Manual Towing Wiring Diagrams thanks to @FLEngineer :
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-7pin-pg4-pdf.3922/
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-7pin-pg2-pdf.3923/
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-4pin-pg1-pdf.3924/
https://www.ranger5g.com/forum/attachments/wiring-diagram-towing-7pin-pg3-pdf.3925/
On to the install:
1. Disconnect the negative terminal of the battery. Make sure you have something preventing it from arcing back over to the terminal.
2. Locate the four trailer wires on the driver's side kick panel on the left side. Yellow/Orange(Red), Green/Black, and White were taped together, coming out of the firewall. The first time I looked for the wires, I missed the Violet/White because it's actually taped to a different harness to the left of the three other wires. On my Ranger, the whole butt connector end was taped over so it looked like one continuous normal wire.
The four wires are:
  1. White - Ground
  2. Yellow/Orange(Red) - 12V Power
  3. Green/Black (Solid Blue according to Ford Service Wiring Diagrams) - Trailer Brake Controller Out
  4. Violet/White - Brake Light Trigger (Brake On/Off)
Note: On my truck (Purchased 01/2019), Trailer Brake Controller Out Wire is Green/Black. According to Ford Service wiring diagrams, the wire is supposed to be blue. On newer NA Rangers, it has been reported that the TBCO Wire is Blue.
The Tow Pro Elite comes with a wiring harness that plugs in to the main unit and the other end has 4 wires that you will be splicing to the Ranger's tow wires. The wires on the harness are:
  1. White - Ground
  2. Black - 12V Power
  3. Blue - Trailer Brake Controller Out
  4. Red - Brake Light Trigger (Brake On/Off)
3. Butt splice the wires from the included wiring harness of the Tow Pro Elite to the corresponding four wires in the kick panel. BE SURE THERE IS NO POWER RUNNING IN TO YOUR WIRES BY MAKING SURE THE BATTERY IS DISCONNECTED. Cut off the black ends of the four wires of your Ranger. I used Crimp & Heat Shrink Waterproof Butt Splice Connectors because I was originally planning on routing the wires under the carpet in the footwell and because of snow and post-surf days when it's too cold too properly towel off and I just jump in to my truck wet. Although regular butt splice connectors are probably fine.
If you've never butt-spliced wires before it's pretty straightforward. You strip off about .3" of the wire sheath exposing the copper wire. Insert the exposed wire in to the barrel. Do the same with the wire that you will be splicing together into the other end of the connector. Then crimp down on the barrel. Slight tug to mke sure that you crimped down hard enough and that the wires aren't loose. If using heat shrink tubing, heat shrink the tubing with a heat gun, making sure to evenly heat all sides of the connector. Careful if using an open flame. If you mess up, you can always cut the wire and re-strip. Be mindful of where you cut and splice the wires, the more wire length you keep, the easier it'll be when routing it towards the main unit wherever you decide to place it.
4. Find a suitable place to mount the Remote Control Assembly. You'll need a minimum for 46.5mm plus a recommended distance of 43.5 for the RG45 cable that connects the main unit to the remote head assembly.
5. Once you've chosen a spot for the remote assembly, you'll need to drill 2 holes in to the console panel/dash panel/knockout switch. One 10mm in diameter and another 3.5mm, the center of the holes 7.5mm apart. It's obviously easier if you can remove the panel first. I purchased the Lightforce Switch Fascia so I drilled the holes at the center of a knockout switch blank that was included.
6. Once the holes are drilled, place the Remote Head Assembly behind the trim panel, with the Control Knob shaft and LED coming up through the holes. Place the Remote Bezel over your panel covering the LED. Some people skip this step, but I like using the bezel to remind me what level gain I'm currently at (12 o'clock position). Screw the Remote Head Nut on to the Remote Head Assembly. Torque to 0.8Nm. Turn the knob fully counterclockwise. Place the Remote Head Knob on the shaft with "0" in the 12 o'clock position, alligned with the bezel (if you chose to install it).
7. Find a suitable location to mount the Main Unit. You can mount the unit in any orientation as long as it's secure and doesn't move at all. It also needs to be in a location where it reaches both wiring harness and the RG45 cable to the Remote Head Unit. I used an empty hole behind and above the gas pedal in the footwell. I fastened it with a #8-32 screw 3/4" long (could easily use a 1/2" long screw), a 1/8"x1" fender washer, and a #8 locking nylon nut. I just happened to have those lying around, so that's what I used. I don't think you could go any larger of a screw to fit the main control unit, maybe an M4 screw. This was probably the most difficult part for me because there's not a lot of room to work. I also had to use a really small socket wrench to fit behind the hole in the bracket while screwing down the screw.
8. After securely mounting the Main Unit, you can now run the wire harness to the main unit and plug it in. I ran mine behind the fuse box, below the steering column and dropping down to the Main Unit.
9. Plug in your included RG45 cable to Main Unit, route it towards your Remote Control Head, and plug it in to the back of the Remote Control Head.
10. Install your Remote Control Unit in its final place and replace all trims.
11. Reconnect the negative terminal of your battery.
12. Pat yourself on the back for a job well done!
The Tow Pro will calibrate itself automatically and takes about 20 brake applications before it's calibrated. Consult your manual for more info!
You can use any cat5 RG45 cable to connect the main unit to the remote head. At first I used a 3' purple cable I had lying around. I then switched it to a 3' flat cable since the switch fascia didn't leave for much room, and while it could have worked, I decided to use the flat cable to leave more room for possible wiring projects. The 3' cable left me with about 10" of extra cable at the main unit to the fascia. I bought the cable here ($0.89!):
https://www.monoprice.com/product?c_id=301&cp_id=30102&cs_id=3010201&p_id=9547&seq=1&format=2
Update: Had zero issues after install and the REDARC Tow Pro Elite works just as expected. Trailer brakes are applied in proportion to the truck's brakes and trailer brakes can also be applied by pushing down on the REDARC Remote Assembly button. LED gives visual feedback on braking power applied. Have towed three different trailers with brakes, including an almost 1000 mile trip to and from the Grand Canyon from Southern California with no issues.
Happy Towing!
Looks great! Do you have a link and price for the fascia trim that you swapped out and mounted the button to?
oggvorbis
oggvorbis
Pablo
Victorville, CA
2019 Ford Ranger Lariat FX4
Aliby
Alistair
Ken-Caryl, Colorado
2019 Ford Ranger SuperCrew Lariat FX4, Tow package, Magnet with Black Sports package
Hi Jim, can you let a photo of where you mounted the Takonsha Prodigy P2? I need to mount mine too.
Phish806
Iowa
2019 Ranger XLT
I am assuming the computer flash rumor that was started awhile back was just that - A rumor - and not a real thing. There is no way for the the Ranger PCM to have any control over a redarc controller or a ford branded controller (if it truly is the redarc re-branded) with only the four wires that are hooked up from the controller to the vehicle. There would be no way to get the signal to or from the dash control to the Redarc unit.
MT19RANGER
JERRY
SIDNEY, MT
So true, it would have to be an integrated controller and it's not offered yet.
Lukaranger
Ontario, Canada
Ranger XLT Sport
Before I pull the trigger and order the controller I just wanted to know if the required 4 coloured wires are easily visible without removing any covers/panels.....just so I can first have a quick look to see what I'd be getting involved into.
Edsel
North Carolina (Wilmington)
2024 Jeep Wrangler Willys 4Xe
Engineering Professor
You have to pull the kick panel to the left of the fuse box. They are not easy to find and, IMNSHO, cut too short. IIRC, they are bunched together with some blue tape. All that are used are the blue and yellow and getting the heat shrink off the end of them is a PITA. Of course, you can follow the instructions and just cut it off completely, but later you will be wishing for that extra 1/2" or so.
Lukaranger
Ontario, Canada
Ranger XLT Sport
Reading the other thread about the new version 3 model that Ford is selling now (that has the extra Lumen module for the AEB), would anyone agree this new version is the way to go OR is the "older" Redarc version good enough when you can just turn off the emergency braking feature?
