Rear fire extinguisher installation
OFC Ranger
Jack
ZR2
Jhbryaniv
2023 Ranger Tremor
OFC Ranger
Jack
ZR2
That's essentially what I use... That and some fire starters.
And if they don't work, I have a blowbtorch I carry in the toolbox. LOL
I mean I still have a stash of regular lighters and regular matches I keep stored in zip lock bags inside other bags, but shit has to be real bad for those to come out at this point in the game.
1pt21gw
West Coast
Ye' Ole Traveler
Jhbryaniv
2023 Ranger Tremor
I honestly don't have any matches.
I don't think I've owned any since you stopped being able to buy strike anywhere matches.
OFC Ranger
Jack
ZR2
Well I figured lighters can stop working for any number of reasons, so 3 is 2, 2 is 1, and 1 is none.
1pt21gw
West Coast
Ye' Ole Traveler
So am I to understand that you can mount an Element Extinguisher in the bed, maybe kinda protected, like under a rail that the sun and water "might" reach it and the that is ok?
OFC Ranger
Jack
ZR2
Ya but you can't toss those into a pool of flammable...
Sure you can, just find something to get the activation button to stick?
I would imagine that it would be perfect for something like that. The stupid cigarette trick from the movies doesnt work...
carmigo
Carmigo
Tupelo, MS
N/A
We help people sell their Rangers in the easiest way possible.
Decided that I needed a fire extinguisher a little while back. I don’t like the larger canister extinguishers because of the life-span and size which makes mounting tricky.
I went with an Element E50 extinguisher stick. These things are awesome. Last longer than a smaller canister, and do not have a shelf-life. (Solid state material) they do have some drawbacks - cost and not being able to stop it once it starts when compared to a canister. But for me the pros outweigh the cons, making it well worth it.
I ended up drilling a few holes I. The rear under seat storage compartment and mounting it under the rear passenger storage space.
Fits perfectly and is out of the way and tucked in nicely.
Bolted in with stainless steel bolts/nuts/washers. Retention strap with some rubber grommets to clean it up as well. I ended up cutting the screws shorter with a Dremel because it was hitting the body underneath. Once cut shorter it fits perfectly.
All-in-all I’m super happy with how it turned out!
Looks great! This is one really important thing to keep in your car for emergencies.
DangerRanger84
Ryan
West
2021 Ford Ranger Lariat
Thanks man! After witnessing another vehicle burn to the ground from a small fire that easily could have been stopped by a small extinguisher, I figured it was time to at least get somewhat prepared lol
carmigo
Carmigo
Tupelo, MS
N/A
100% right on that. I like to keep a window breaker in my car just in case I ever accidentally drive in a lake. You never know...
Whiplash
Kern
The southwest Missouri Ozarks
2021 Ranger XLT FX4 / 2004 Mazda RX8
I have a tactical LED flashlight with glass breaker and seat belt cutter in my center console box...and Auto/Marine canister extinguisher mounted in the truck bed. ...also keep a mid length handle , full size serrated blade shovel (Kobalt from Lowes) good for grass fires, mounted in the truck bed....
