Noob octane error - filled 1/2 tank w/85 octane
Thanks Dave, is there any tutorial or specific video that you know of I could watch to learn more about the mechanics of it. Where would be a good 101 course so I can understand more of this? I hate asking you guys all the time.
No worries Andrew, that's what the forum is here for. I don't know of any specific videos but in this same section there's a ton of info on all the tunes available. If you're worried about retaining your warranty the Ford tune will do that but you are locked into using only premium fuel. You won't get as much hp/tq gains but it's still a very noticeable difference over stock. 5star has a warranty available for purchase with their tune and IIRC it's close to $1,000.
dtech
colorado
ye olde octane debate . Most makers give guidance against running anything lower than the recommended octane for boosted engines - irrespective of altitude. This because it's inherent for a turbo engine to raise the boost level to compensate for lower air pressure such as seen at higher altitudes. Whether or not the Ford engine mgmt system can fully compensate for running 85 is for me an unknown, I choose to believe in the owner's manual.
I'm of the opinion that Ford has tuned the engine to run quite well on 87 octane, this comes from using 91 and 87, I can tell a difference but it's not one I'd term as all that much - my point of reference are Saabs I owned where they were sluggish using 87 octane - the recommended octane was 91, so these engines were tuned to deliver peak performance using 91 , the difference was immediatedly noticeable.
And then there is the wife's Hyundai - 2.0 turbo, 87 is the required/recommended octane, using 91 makes very little difference in performance - a clue that the engine mgmt system is not designed to leverage higher octanes - some engine mgmt system are not - many recent ones are engineered to optimally use a range of octane levels.
So given the price of premium it's 87 that feeds the Ranger.
Groo
ohio
Ranger 2020
Gainfully umployed 5 Pointed Star
Groo here
My friends....
This is a boosted engine and does not care if it is at sea level or Denver.
The turbo makes up for the pressure change.
If the engine needs at least 87 ,, that is it.
I hauled gas and testing is minimum 87.
Drive easy till you can put a gal or 2 in the tank then put the highest you can get ,
Or ,I would just put a booster in and forget it...
slowmachine
New Hampshire
Groo here
My friends....
Boost is relative to ambient atmospheric pressure, not absolute, or even corrected to seal level. The turbo increases air density in the engine, so performance is better than without it, but definitely does not fully compensate for the altitude difference. I’d still run at least 87, if not the highest octane available.
Groo
ohio
Ranger 2020
Groo here
Compaired to the boost pressure the engine runs at, the difference is a pittents.
My cobra would boost 10psi above local pressure regardless.
The wast gate limits the pressure,, As long as the turbo outputs enough to open the gate it
will adj for higher or lower local pressure.
This is how an aircraft engine works at higher alt.
dtech
colorado
Groo here
Groo here
waste gates on (modern) turbos operate either through vacuum actuated or electrical solenoid (Ranger) . It is reasonably accurate when said that turbos "create their own atmosphere" referring to the ability to compensate for less atmospheric air pressure than 14.7 bars - which is the typical reading at sea level. Hence the requirement for a min of 87 octane for many boosted engines irrespective of altitude.
Groo here
My friends....
I've driven boosted vehicles at altitude for over 20 years. Including OTS tunes for 93 on our lowly 91 here.
Octane rating is basically resistance to pre ignition. Which is something you want at the higher effective compression ratios of a boosted engine. However, oxygen is needed for pre ignition, and the higher you go, the less there is.
When Ford states that 87 is acceptable they are basically saying "Regular" fuel. As 87 at sea level is the equivalent of 85 at altitude. Both are sold as regular grade. At sea level, or even Kansas, you have the choice of 87, 89,93. Here at altitude, 85, 87, 91. Because less oxygen equals a lower propensity to preignite/knock. It's basic science.
There's a reason the performance tunes are listed as 91/93. Because in many places in the US 91 IS 93, essentially.
That being said, I run premium wherever I'm at on boosted vehicles. For the Ranger that's more for performance/insurance than anything. I wouldn't sweat a half tank of 85 here at all.
slowmachine
New Hampshire
You are almost certainly correct, and I am aware of the reduced octane requirement at altitude, but that isn’t in the owner’s manual. Does 85 satisfy the warranty conditions, or are you giving Ford an opportunity to weasel out of their obligations? Gas is cheap; engines are expensive.
Can't say I disagree there. Which is why I wouldn't do it on the regular. Still, I wouldn't be concerned at all about a half tank of 85 mixed with a half tank of 87.
If I were, I'd drive gingerly for a half a tank, then top it off with 91 and call it good.
Gazmic
WA
Machinist
I wouldn't worry about it at all for 1/2 a tank. I took a road trip from Washington to Utah a year and a half ago. I couldn't believe ho much "cheaper" the gas was in Idaho and Utah. It wasn't until the last fill on the way back at the Idaho / Washington state line that i noticed I was running 85. I ran 3-4 full tanks without any issues.
VAMike
2019 Ranger Lariat SuperCab
The percentage of oxygen in the air is the same at sea level and on top of a mountain (about 21%). What varies is the air pressure, which determines how much air (by mass) is in a given volume; at sea level that's 14.7PSI and at 10k feet that's 10.2PSI. There's less oxygen by volume at higher altitude, but that's irrelevant if you're squishing more air into a given volume with some sort of pump! If you have an engine at sea level boosted by 10PSI you've got about 25PSI in the cylinder and the same amount of oxygen (by mass) you'd have at 10k feet with 15PSI of boost. The computer sets the boost pressure based on what it takes to get a certain amount of oxygen into the cylinder to generate a desired amount of power, so the main difference is that at higher altitude you tend to need more boost (higher pressurization) for the same power output. It is true that the final pressure in the cylinder will be lower with max boost at altitude vs max boost at sea level, but the engine typically spends most of its time at lower boost levels and at those lower levels the altitude is compensated for (so the octane requirement is what's stated, with no "altitude reduction").
dtech
colorado
Numerous considerations - but I think this video does a good job regards explanations and the pros and cons of using 85 octane in modern cars - they don't take a firm stance either way just outline the risk factors. The video was apparently created in response to people asking about octane requirement in Ford's F-150. I find it an interesting debate about using 85 octane in high altitude whereas it's not infrequent for some to say they will only use premium because it'a turbo charged engine - which I believe to be well - old school thinking.
https://www.torquenews.com/14093/how-85-octane-fuel-can-destroy-your-engine-and-void-your-warranty
jblc
JB
USA
2021 XLT FX2 supercab
Thanks... I saw that, but it didn't say anything about engine longevity with higher octane (as others in this thread were implying). I can, of course, see that higher octane is better performance.
What about engine life though, as others had eluded to in this thread?
Aonarch
Alec
North GA/ Montana
Not recommended by Ford and performance shops. This stuff leaves nasty deposits.
Even at altitude 85 is no bueno. That stuff is left over from the old carb days.
But the computer is smart enough to adjust. Just avoid WOT (Wide open throttle). At a quarter tank fill it with the highest octane that you have and you'll be fine.
Btw 89, is just 87 and 91/93 mixed.
