- First Name
- Dennis
- Joined
- Dec 20, 2019
- Threads
- 80
- Messages
- 6,817
- Reaction score
- 41,639
- Location
- Living The Dream
- Vehicle(s)
- 2019 Ranger XLT FX4
FTFY ?Wrong on that!
No damper here.YET
No damper here.YET
Easiest way to search this forum is to skip the search feature. It was clearly designed by Sean Penn after a night of booze and cocaine at the Viper Room followed by waking up naked on the pier.Most of those items have been covered thoroughly on here but sometimes the search function isn't the best.
Google is also an option from the forum search button.Easiest way to search this forum is to skip the search feature. It was clearly designed by Sean Penn after a night of booze and cocaine at the Viper Room followed by waking up naked on the pier.
Just go to Google.
Type in Ranger5G.com, a space, then your search words or criteria.
That seems to work the best.
Don't hold your breath unless you want to turn blue and pass out.FTFY ?
I found this works much better.Certified scuba diver here.
Actually no, just likely certifiable ?
My damper persuasion skills are very limited so I'll leave it up to Dave @AzScorpion
Don’t do that, I’m on Acid …I found this works much better.
None here either.Wrong on that!
No damper here.![]()
must buy damper... must buy damper... must buy damperI found this works much better.
I already spy something you're gonna need, eventually anyway...Well it's officially mine. 250+ miles today, spilt coffee and dropped fried chicken crumbs in it.
I connected the wifi to my phone while I was out today and there was an update available. after updating the Ford Pass is working.
Oh, my first enhancement showed up today.
Indeed, if you do get a catch can @Kafn8td do not get the Mishimoto one. I did at first and switched to the UPR Dual Valve and I'm much happier now. And yes, it is a pain to install. But so far, I've installed everything in my detached garageMy number one recommended upgrade would be rear shocks and at least the global leaf springs.
If you're considering a catch can be prepared for physical pain and mental anguish. I'm totally invested in mine, it will go to the crusher with it.
