New Driveshaft Design in the works
KJRR
KJ
Cleveland, OH
Professional Curmudgeon
Design flaw, should be 1 piece.
Now that’s a drive shaft - imagine the slip bump from that one - it would throw you through the windshield
Living The Dream
Just add a leveling kit and it will fit.
There may be a little occasional rubbing but nothing major.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
Yeah but it would take you all day and 10 cans of grease to fill the bearing!
By my calculations and specialized engineering guesstamation it will.most likely need 3 55 gallon barrels of grease per service
ctechbob
Shawn
2020 Ranger XL/FX2/STX
Adult Daycare
For the story behind the joint. Had to do some looking. It is a damn big assembly.
Double-drum winder, named after its inventor, Robert Blair, where both drums incorporate two winding sections, normally for multi-layer winding, often referred to as a BMR winder, BLAIR multi-rope winder.
Since these kind of machines require a lot of room, it may be necessary to arrange the two drums at an angle to each other in order to maintain the necessary rope fleet angles. In this case, each drum receives its own machine shaft, which is mechanically coupled via a universal joint.
Something else to note. Check out the 64 pistons worth of hydraulic braking on the outer edge of the drums. They're not playing around with being able to stop those things from turning.
Cmar
Cam
Australia
Ford Ranger PX
Medical Scientist
But I imagine since it won't turn very fast and the angle is slight that you wouldn't have to do it too often.
