TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 45
- Messages
- 3,942
- Reaction score
- 9,896
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
- Thread starter
- #91
OK, I have read over the investigative work of Aero Tech(for the 3rd time) and looked at detech's approach to the BMS battery management. Those PDF files supplied by Aero Tech were most interesting to me, esp #5 Smart Charge Explained from the Ford & E Transit manual.
Thanks to both of you gentlemen for your sleuth work on the Ranger charging system.
I had no idea Ford had bastardized the charging system so completely in the name of EPA / CO2 / greenie mandates. I must wonder if the tradeoff is worth it from a carbon foot print perspective.
You save precious little fuel vs the cost of recycling the old battery and manufacturing a replacement every 18 months! I don't think .1 of a mile/gallon over 18 months adds up to the $200 cost of a replacement battery during the same time period.
This makes no sense to me at all. Seems the world has traded critical thinking skills and logic for feel good initiatives (or if I were suspicious, I would think that this is simply one more way to separate me from my money.)
I want a reliable charging system that maximizes battery life. I believe that I have achieved it in my previous autos, and I want something similar in my 5G Ranger. This means I want a conventional charging system (or as close as I can get) on my Ranger that will allow my onboard desulfator to work its magic. This is my objective. What I don't want to do is to continuously need to charge the battery in an effort to extend it's life. I'd rather add the desulfator and forget about it. But Ford has thrown a monkey wrench into the works by not suppling optimal battery voltages to activate the desulfator or charge the battery to 100%.
So here are a couple of questions that when answered will hopefully point me in the right direction.
1) Can Smart Regenerative Charging (SRC) Override ( Conventional Charging - Third Party High Power Mode in the Ford Transit) be implemented in the 5G Ranger?
2) Does unplugging the BMS sensor achieve the same thing?
I do know that my smart charger does not charge the battery to full SOC if I connect it through the BMS sensor as advised to do by Ford. My battery voltage levels with the charger active and connected as Ford advises (negative connected before the BMS sensor) were at 12.5v measured at the battery terminals.
If I charged connected directly to the battery I saw the 13.5-13.8v volts that I expected from previous experience. This leads me to believe that the BMS is active even with the truck isn't running.
I am leaning towards simply unplugging the BMS sensor at the battery and forgetting about it, and letting my desulfator do its thing.
- T
- via Forscan settings,
- or some other unknown method, aka the jumper from Pin 1-3 in the plug under the seat in the Ford Transit
- T
