I had a leveling kit on my truck for about a year with no issues until I decided to go with a full 3.5” lift. Wife’s truck currently has a leveling kit installed and no issues either. From what I’ve read, 2.5” leveling kit is as tall as you can go before you need to be concerned with CV angles. My lift kit came with a 1” drop bracket for the differential to keep the angle the same as what a leveling kit would be. I have 60k miles on my truck and zero problems.2020 ranger xl 4x4 i want to raise the front 2" just for leveling.Has any one done it then had a problem with the cv axles at a different angle wearing out
You shouldn’t need a drop bracket just for a leveling kit. I put a 2.5” level on my wife’s truck and didn’t touch the differential. I did swap out the upper control arms though. I didn’t like the angle of the ball joints, they looked close to maxed out. I had some extra control arms that I accidentally double ordered for my lift kit so it worked out. I don’t think that was really necessary but I figured I had the parts laying around so might as well.im only doing a 2" do you think ill need a drop bracket.If so where did you get your kit
Ford will put their 2” leveling kit on the ranger without adding a drop bracket so you’re fine. The only reason that’s necessary is if you’re going past 2.5”
