armoredpig
- Thread starter
- #1
Hello friends, I recently discovered this greasy substance on my passenger side rear hub. I can't tell if it's the dreaded axle seal leak or a brake fluid leak. The caliper pin boot doesn't look right.
I checked my diff fluid and thankfully, it was not low at all. I plan to check the brake fluid today after work (I have dot4 LV arriving today).
In the last picture, I've cleaned it off as best as I can. Going to to watch it to see exactly where it's leaking from.
What do you guys think it is? Should I replace both the axle assembly (comes with new seals) and the rear caliper?
I'm also of the mind to do my rotors and pads because I get a slight shake on braking that I think is related to this.
