Installing a rear locker on Ranger XLT 4x2
Veesy
Michael
Orange County
Ford Ranger 4x2
Construction Worker
So I am getting a New Ranger but honestly didn’t think about off-roading and it’s to late to change packages. I was wondering if anyone had help on after market lockers for off-roading. I don’t know if I am gonna go much but wanted the option. Because I really just wanna go on trials nothing hardcore. Any help appreciated!
arb is the one id go for. not cheap or easy fast install but will work well. maybe if you could find one from a salvage yard from a ranger with the locker already .
Jason B
2021 XL STX SE 4x2
machinist
Plan on a new Ring and Pinon with your locker as the old Ring gear is welded to the differential and likely cannot be salvaged...
best,
The quote above id from another post, I don't think it is feasible to add a locker. Probably easier and cheaper to find a used locking diff.
machinist85
n/a
n/a
I'm in the process of doing this myself and have done a ton of research. An ARB air locker with new gears, carrier and compressor would cost about 3K. Even though my 2020 didn't come with an e-locker it still has the relay and fuse for it. Replace your start/stop button with one for an e-locker and turn it on in Forscan under BCM. The power wire for e-locker is in the lower harness on the driver side frame rail. Tap into that wire then swap in a used e-lock axle. They run about $1,600-1,800. The biggest problem I've had is finding new u-bolts. Ford's had them on backorder for a few months now.
slowmachine
New Hampshire
Last time I looked, a complete rear axle with the factory e-locker was going for about $1700 from salvage yards. Look at car-part.com. ARB is great, and the onboard compressor might make it worth the extra cost if you need it. If not, the Ford parts seem like a good buy.
jleds
Jay
Honolulu
2019 Ford Ranger XLT
Hey man! Just out of curiosity Any luck on the OEM elocker swap? I'm thinking of doing the same
machinist85
n/a
n/a
I just got the u-bolts and nuts I ordered from Ford at the beginning of the year. I have the electrical part sorted out. Now I just need to get around to swapping the axle. My goal is to have it done before winter so I can use the locker in the snow.
jleds
Jay
Honolulu
Awesome! Good luck man! I'm excited to see how it turns out, and probably bug you for some tips lol
Squatchranger
Orlando
19 ranger lariat
Is yours a 2wd though?
Squatchranger
Orlando
19 ranger lariat
I wouldn't do it locker or not you have a 2wd coming a locker will get you a bit further but ultimately 2wd is not meant for most offroading (with some exceptions) It is a sellers market if you are getting a good deal on the 2wd I would flip it for a 4x4 if you can find one or do an order in july when the new banks open
Jason B
2021 XL STX SE 4x2
machinist
Rear lockers are available on 2WD from Ford, they are called FX2. I've seen a couple around here. Sometimes it's nice to be able to lock up the rear on a 2WD, such as when ramping a boat or racing a Tacoma.
Cabose-1
Eli
Student
Momentum is king!
Traction control off, skinny pedal down, go go go!!
Just be careful, no armor on 4x2s
Careful with the front airdam thingy and don't worry about hitting the side steps.
Have fun. Lol
Squatchranger
Orlando
19 ranger lariat
Of that I am well aware however if you read what the op said he is not using it to ramp a boat or race tacomas (no need for the locker tacomas are slow af) He wants it for offroad and despite what people try to say 2wd has very limited uses offroad and 4x4 even with open diffs will go way further than 2wd with a locker
just my view here but unless the ranger is gonna be a long term play toy it may not be worth the effort or trouble to mess with a locker. if your going to go that much trouble it may be a better option to just buy a 4x4.
Dereku
Chicagoland Area
When I moved to Phoenix I drove from SC in 2 days. According to this forum I never should have made it. It was a 2008 f150 2wd with 230k miles at the time. I-40 was shut down west of Albuquerque NM and I had a flight to the west coast to get the U-Haul 10 hours later. I took a 30 miles desert road that was full of ruts, giant holes I drove around and tons of water.
Guess what my 2wd had? Yup a locker. A locked 2wd and some serious knowledge of wheeling will get you pretty far. I was happy with it in Midwest winters and muddy farm roads. Get a locker you will enjoy it. Also get off road recovery gear, then when you do get stuck you can get out.
