- First Name
- Chris
- Joined
- Mar 15, 2020
- Threads
- 169
- Messages
- 7,682
- Reaction score
- 10,956
- Location
- Elizabeth, Colorado
- Vehicle(s)
- 2012 Nissan Frontier, 1994 F150 XL, 2022 Ford Transit
- Occupation
- Field Service Technician
I spoke with Bilstein a while back(at least 2 years ago) about the 6112 and they stated that they highly recommend different springs that are not included with the shocks(and not available through them) if you want a Bumper and Winch add on up front.No need to change out your current coilovers. The 6112 Bilstein have 600 lb
spings and will support the weight of most
bumper and winch combos....The 5160 are a firm digressive shock , that will work best with a softer progressive spring pack.
The swap in of the ICON extra leaf is good for up to 700 lbs constant weight. You will not lose load capacity but the added lift of the spring ,(1.5") will compress the first 1"
earlier in the cycle....the OME leaf pack with the digressive shocks will be a little rougher on the street...
Also when it comes to shocks and springs it is always best to match brands so you have best comfort and control.
As for the constant load for the Icon Leafs, is that with the loss of 1 inch of height? I ask because Icon Advertised it as max 600
