Fuel in oil
quirkybar8
Indy
2019 Ford Ranger 2WD XLT
This is on the very next page of the 2019 manual. Sure you read far enough?
quirkybar8
Indy
Still there on page 266 for 2021. I actually thought that was an interesting way for Ford to finally address this problem.
Motorpsychology
Prescott, WI
Vagabond
But here is the manual from the 2015 Mustang. It calls out going over the upper hole:
But the 2021 manual does not:
I
Back on page 265, it states that the "oil consumption of new engines reaches its normal level after approximately 3000mi (5000km)."
...My interpretation is that overfilling when adding your own oil is bad, (p266) but fuel-related dilution not so much, as it is generally self correcting(p265).
My experience is that my oil level was at the full dot at 5300mi before a recent Ford Quick Lane oil change, and ~1/4" above at less than a thousand miles after; both checks after sitting overnight in a level garage. I'll check it again each thousand.
OrangeStreak
New Mexico
Question about oil level?
I had my 1st oil change last week at a local Ford Dealer. The "Oil Change Required" notification came on several weeks before I had the change done at 4231 miles. I assume they put in exactly 6.2 quarts because the oil level was on the line at the top of the crosshatch. The reading was taken after the truck set in the garage overnight. I am curious if you guys are getting the same level reading on your dipstick (pic. below) after you do an oil change? I will send a sample of the original oil to Blackstone for analysis and report back their findings. This dealer recommends 5000 oil change intervals which has been my standard practice.
JKocot
Montpelier, VA
2020 Ranger Lariat SCrew FX4, 2018 Explorer Sport
Senior Systems Engineer/Former Marine
I am at 15000 miles and the level is at the max hole. Last oil change was at 10550. Oil level was measured about 2/3 up the hashed mark area (Had the dealer score the dipstick)
Motorpsychology
Prescott, WI
Vagabond
I had my 1st oil change last week at a local Ford Dealer. The "Oil Change Required" notification came on several weeks before I had the change done at 4231 miles. I assume they put in exactly 6.2 quarts because the oil level was right on the line at the top of the crosshatch. I am curious if you guys are getting the same level reading on your dipstick (pic. below) after you do an oil change? I will send a sample of the original oil to Blackstone for analysis and report back their findings. This dealer recommends 5000 oil change intervals which has been my standard practice.
Your Oil Life Index is Interesting. I changed mine at 5745 mi and my OL was still 48%. I wonder if the Monitor accounts for fuel along with other contaminants and triggers the Service engine soon at some threshold? I understand its pretty comprehensive system.
OrangeStreak
New Mexico
Chris,
My oil life was at 0 when it was changed. I would like to know too how the oil index is calculated. I read somewhere that temperature is one factor but can't confirm that. I asked the service dept. at the oil change and they weren't sure. They thought it was determined on a time and mileage basis?
CO2Ranger
Wonder what changed?
Not sure what I'm missing but both images you posted specify not to add engine oil past the max mark or engine damage could result...
JKocot
Montpelier, VA
Yep - bad day. Trying to do more than two things at once. Multitasking was never my strong suit. I stand corrected. I was trying to show the 2021 Mustang manual does not call it out like the Ranger manual. But I would be incorrect.
N. J. Jim
Vineland,N. J.
2019 Ford Ranger Lariat
I have 3500 miles since my last oil change and my oil life reads 65% !
fusseli
EE
fusseli
EE
