Forward Radar
HAMMERTIME
Hamilton, ON
2020 Ranger XLT, Hawk Topper
Driving in Ontario in the snow is causing an issue with my front radar below the main grille. It gets covered in snow and the radar shuts down so no adaptive cruise and no forward collision warning. Has anyone ever had this happen to them? Maybe someone has a work around??
FORD does not. My dealer says they get a lot of complaints about this. Stop and clean it off is their solution. Great engineering Henry!!
Peter949
Peter
Irvine, CA
2024 Ranger Raptor
Yup, I got a warning it was no longer working with light snow.
EJH
Ed
Subarus, 2021 Ranger
Yeah. It happens. It is worse for me in freezing rain. I wish there was a heating element on it.
Rp930
Denver
unavoidable.
All makes have the same problem.
khyros
2019 Ford Ranger Lariat Crewcab FX4
So I'm planning on getting a ACC relocating bracket (from Fab 4, but I think ADD has one as well) when I put a winch on my truck... I'm wondering if the relocated position would be better protected and less prone to getting caked in snowy slush garbage.
As a side note... last winter when it happened to mine, I cleared it off by hand, but it still didn't work. Furthermore, I couldn't even use normal cruise control. I know on the in-law's Escape, they can change it to normal cruise control and just lose adaptive... What is everyone else's experience with that?
erty176
Appleton, Wisconsin
2021 Ford Ranger Tremor
Designer
Can use regular cruise control. It's in vehicle settings via the dash. Just have to turn adaptive off. Haven't found any good work around other than to just not rely on it in the winter.
khyros
Yup, that's what I thought... mine was grayed out completely and wouldn't let me change it.
halligan1201
Byron, IL
2020 Ranger
Emergency Management
Moving it higher might help but likely not. Every make I've ever driven with this feature has had the same issue. I just switch mine to regular cruise on snow days. You'll also find that the features that rely on the windshield camera won't function when there is snow and ice built up in front of it.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
Frankly relying on ACC in bad weather sounds like a bad idea anyway.
HAMMERTIME
HAMMERTIME
Hamilton, ON
Thinking more for when you get snow for a few mile stretch and drive out of it back on dry roads. Then go to use the cruise and it won't work.
No worries about when I'm on slippery roads - it stays off.
Dahveed
Central Kansas
Pharmacy Consultant
I remember seeing someone relocated the radar module to behind the grille, but I don't know that that would help much with snow.
EJH
Ed
Except that is also disables the emergency braking, which is nice to have. Also, ACC can 'see' better than I can in many situations (fog, snow, rain). The radar signals are not affected by poor visibilty. Still need to slow down, but the extra safety system is good.
Does loosing the radar disable AEB also? My XLT does not have ACC but I still have AEB, it uses the camera up by the rear view mirror. I though it used both the camera and the radar when available.
Motorpsychology
Prescott, WI
Vagabond
I had a 2018 Escape, the radar transmitter was behind the lower valence panel. When it snowed, the panel would get smothered with road glop and trigger a message on the display admonishing me to get out in the storm in traffic and clean off the "Camera." Fortunately it was easy to disengage with a switch on the end of the turn signal stalk and return to normal cruise.
