FORScan Modifications
Roby65
Roberto
It
Ford ranger wildtrak
Eletricista
ciao a tutti sono nuovo su questo forum, volevo conoscere i codici per forscan, per azionare i fendinebbia nel girare le ruote grazie
hello everyone I'm new on this forum, I wanted to know the codes for forscan, to operate the fog lights in turning the wheels thanks
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Welcome!
All the codes are on the wiki post at the start of this thread.
And heads up these are focused at the North American Ranger - not sure how it will apply to your Wildtrack
Roby65
Roberto
It
Eletricista
Welcome!
it is I who do not understand ? but I do not see the codes
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
You don't need the codes for that, that's a UI option to change, with no need to edit HEX codes.
Roby65
Roberto
It
Eletricista
no they don't work I can't understand where I'm wrong ..........
it works only with the indicator running
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
As was mentioned before, the non-NA trucks are setup *very* differently than the NA trucks are, and many of the FORScan modifications are unlikely to translate between models.
Roby65
Roberto
It
Eletricista
Glocker
Boca Raton
I'm excited! A coworker sold his Ford truck and came by my office and dropped off his dongle so I can play with FORscan. It looks like I have a lot of reading to catch up on to see what I want to mess with and what I want to leave alone!
Wasatch
UT
Ranger Supercab
For "Bambi Mode" (allow high beams and fog lights simultaneously) It seems like this is a multi-step process. I do not want my fog lights as DTRL, or to turn on when turning.
Question:
Is there an option to keep the function of the fog lights the same as factory, but allow them to stay on when the high beams are also running?
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Question:
That is the function of bambi mode. It has nothing to do with dtrl.
Frank
Windsor
2019 Ranger Lariat Sport 4x4
Sync 3.4 latest update build 21020
Is there a way to add Heated Seats icon to my display?
I did not see a GUI in the APIM module.
It is in the APIM configuration, called "seat button icons". Set to heated seats.
Frank
Windsor
I successfully installed Sync 3.2 a few days ago via USB. Then I decided to update my Maps as well.
I downloaded the files from the Ford website, followed the instructions carefully and installed the update.
Got the message Update Complete. Remove USB. The map update was successful except that my steering wheel Voice Control button no longer gives me Navigation commands. Only Phone, Radio, Sirius, Climate and USB. Somehow the Navigation connection is lost. Anyone else come across this. Any suggestions on how to fix this?
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
Please see my reply in the other thread where you posted the same issue….
