FORScan Modifications
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Since I couldn't find the circumference for my actual tire size I plugged in generic circumference and drove by one of those signs that tell you your speed. It was a bit high. So I divided the numbers and got a percentage to multiply the original number. Used that and it's dead on on the second try.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
I like your process, but choice of tools (the radar speed sign) may be questionable as to its accuracy.
I was going to suggest GPS, but same question would apply. But would be interesting for you to compare.
RCMUSTANG
Ray
Los Angeles
I drive by several in different cities and they all match up. So, unless they're all wrong in the exact same way I'm good.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I set mine based on the spreadsheet calculations, manually adjusting the hex.
I then confirmed with my dedicated GPS receiver that I compared my speedo to the recognized GPS speed to, within ~0.25-0.5mph variance which is acceptable to me. I 0% trust those speed signs, they're typically not nearly as accurate.
RAYJAY
UNION DALE PA
any one try this for themes ?? working on a f350 found this in the spread sheet
Sync 3 ThemeAPIM7D0-03-01xxxxx*xxxx--0=Ford Classic, 1=Ford Timeless, 2=Lincoln Timeless, 3=Lincoln Next
xxxxx2xxxx--Lincoln Black Theme -- must also set 7D0-01-02 8xxx xxxx xxxx
mlarma
2020 Ranger XLT 4x2
Computers/Networks
I would be interested to see if that works on the Ranger, too. If nobody else tries it, I may give it a go in the next week or so.
andrejt
Andrej
Slovenija
Ford Ranger Wildtrak 2020
Bike Park Manager
Hello,
Has anyone successfully enabled the Off-Road screen in an European Ford Ranger Wildtrak 2020 and have the ANGLES working? I have enabled it via Forscan :
Off Road GaugeEnables Off-road gauges (enable in conjunction with Off-road Screen)IPCGizmokid2005
Off-road ScreenEnables off-road gauges (enable in conjunction with Off Road Gauge)IPC720-07-02 (x3xx xxxx xxxx)Gizmokid2005 / WhiteLightning19 (AS-BUILT)
but as you can see in the picture, NO ANGLES are displayed - only the steering angle and diff lock icon (if turned on) :\
Do I also need the Terrain Management knob or any other sensors for this to start working?
Many thanks for your help and greetings from Slovenia.
jubreunig
Juergen
Tuscaloosa AL
I would say that the angles come from airbag or ESP control unit. The knob is only for selection.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Hello,
I'm not sure where the angles come from, but I do know that the TM knob is not required for them to work. My angles worked before and after I purchased and installed a TM knob in my truck.
Allen_rubin
Allen
Orange County CA
2019 Ranger XLT Sport
Yeah...I'm not too worried. There is a way to use your VIN to get that as built for your vehicle. I'm more worried/scared of my wife and how mad she will be...lol. I can hear it now..."What do you mean..Uh Oh???"
Old thread, but I just did the install and swap as well, same issue on mine when trying to write miles is cancels at 2%... battery was reading .4 less then it should, so maybe I gotta have it full charged. Swapped the steering switch to lariat as well to try and coordinate with the speedo, now trying to get the as built for a lariat SCCM to see what differs from theirs to mine. Ima order that OBD you got too, mine is the older one that has a switch lol
Allen_rubin
Allen
Orange County CA
I thought the OD was locked, where you cannot make changes to it. I know when the dealership replaced my cluster they kept the vehicle for 3 days trying to reset the OD. They had to call someone in Ford to figure it out. I believe the safety features are in place so you cant roll back the mileage upon sailing the unit. Ofcourse I could certainly be wrong.
You can add miles but not reverse them, that’s why you get a cluster with less miles
Allen_rubin
Allen
Orange County CA
Thats very interesting, so if you get a cluster with less miles then its the same as a roll back. If you are not honest about it anyway. Do the clusters not have a serial number to match the other corresponding modules? Like a hard drive in your computer when its registered?
Whether your honest or not if you don’troll them forward the BCM will always have the correct miles
fslec
Clarence New York
2019 Ranger XLT Sport Livernois Tune
Has anyone tried enabling the "Turbo Boost Gauge" option in the IPC module?
