FORScan Modifications
mlarma
2020 Ranger XLT 4x2
Computers/Networks
Setup it up this morning and I have the NA signs. Yes it does flash when you go over your tolerance setting. I have a 2020 XLT Sport with the 301A package.
I will have to check this out. The build date for mine is 9/16/2020 so maybe I’ll get NA signs.
gaby1963
gabriel
argentina
Fordd Ranger LTD TDCI 3.2 4x4
employ
Here's the modules that need changed in order to get the full Speed Limit Sign reading to work:
IPC > Traffic Sign Recognition = Enabled
2020-06-24 18_02_06-FORScan v2.3.33 beta, Ford Ranger_Courier_Mazda B-Series EcoBoost Gasoline...png
2020-06-24 18_02_33-FORScan v2.3.33 beta, Ford Ranger_Courier_Mazda B-Series EcoBoost Gasoline...png
IPMA > Traffic Sign Recognition = Speed Limit Information Function (SLIF) AND Traffic Sign Recognition Mode = Camera Only On (other modes cause errors).
2020-06-24 18_03_59-FORScan v2.3.33 beta, Ford Ranger_Courier_Mazda B-Series EcoBoost Gasoline...png
This all add the options that need to be enabled in the dash menu:
Driver Assist > Traffic Signs > Always On (It will show up in the area highlighted when it detects a speed limit sign. It will time go blank when you slow down and stop/turn a corner of speed up a lot).
Hi friends, I need you help, I see only MODE TO ipma module "AS BUILT FORMAT" I cant found the line to change to "camera only on", , gabriel
WLFPIR8
Ethan
Central Ohio
whor.us
2019 Ranger Lariat FX4/Sport in Saber Orange
Systems engineer by day, maker and multimedia guru by night.
The Forscan mods listed here ONLY work on North American 2019+ Ford Rangers. You may have better luck in the Forscan forums (via their site).
Are you running the latest Forscan version?
Just a word of advice on FORScan mods. Make sure your battery is in good shape. My son got new tires on his F-150 and I tried several times to update to fix his speedo. It kept giving me a weird "unable to write" kind of error (I forgot the exact wording). Anyway, after some googling, it looked like it might be due to a low battery or something. I hooked his truck up to my trickle charger and the update took the first time. There was nothing obviously wrong with his battery but it was 5 years old and apparently it was just enough to make FORScan have fits.
I guess what I'm trying to say is that if you get weird errors when trying to update, put a trickle charger on your battery and see if that fixes the problem.
RAYJAY
UNION DALE PA
This came today... Now I just need the truck.
all ready have this interface , is there any problem with this one ? or do i need the up dated version ?
and how many years is everyone buying for the software ??
immersion
SLC, Utah
Ford Ranger 2019 Lariat 4x4
Hey all,
I recently got a 2019 Ranger and I am new to FORScan. I am planning on doing some of the FORScan mods (i.e. Offroad display, TM mode) but have some questions regarding warranty. I understand that any modifications could void the warranty if the dealer can prove it was a direct result from that mod. I have couple of questions regarding that:
1. Are there any logs of FORScan accessing the system? Even if I revert values would the dealer be able to see that it was modded at some point?
2. If there are any software updates (i.e. Sync 3 ) do I have to revert back to the default config before installing the update? If I don't, would the software update overwrite the FORScan values to default?
Thanks in advance!
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Hey all,
Thanks in advance!
You'll be fine with FORScan, since it's only modifying config values to your modules. It's not actually flashing anything that could be harmful to the vehicle. Just make sure you take backups of your modules before making any changes with FORscan and you should be 100% fine.
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
2020-06-24 18_02_33-FORScan v2.3.33 beta, Ford Ranger_Courier_Mazda B-Series EcoBoost Gasolin...webp
2020-06-24 18_03_59-FORScan v2.3.33 beta, Ford Ranger_Courier_Mazda B-Series EcoBoost Gasolin...webp
Make sure you follow the instructions! I missed one of the changes in the IPMA and my truck blew up!
JK ?
Wasn't displaying the speed and went back and re-read Ethan's direction, fixed it and it works!
Another XLT w/302a. No adaptive cruise so I guess it uses the lane assist camera.
One question, anyone know why some of us have US style speed limit sign icon and other (like me) have Euro circles?
micl9
Apex, NC
Hey Chris - could you post or send me a backup file of you IPC and IPMA As builts? Maybe I can compare the changes at the Hex level and see whats different to enable NA signs.
Good thought Mike, if you find something please post. I'd like the US signs on my MY2019 instead of the EU signs. Hoping it's not a firmware difference between model years. The camera does recognize the US speed signs so it is probably in the IPC module.
immersion
SLC, Utah
I just did my first FORScan modification to enable the Offroad gauge. It worked beautifully. However, I noticed that the RPM meter next to the fuel level disappeared. I still see the analog view, but it no longer shows next to the fuel. Does anyone know why that happened?
Edit: I reverted back the change but the RPM meter still does not appear.
Edit 2: Added a reference image of what it should look like.
immersion
SLC, Utah
I just remembered that I can configure that through Settings -> Display Setup -> Gauge Display. It seems FORScan updated the value to Fuel Gauge only. My bad!
SBCSD
VictimVille, Ca
2020 XLT Sport
Areospace
Unfortunately I like to live dangerously and did not make a back up! Sorry
