FORScan Crowdsourced Wiki
Al_S
Al
2020 Ranger Lariat
Official Forscan USB adapter OBDLink EX on Amazon listed at $49.95 seems to be on sale for $33.96 today. Since this was on my watch list, I pulled the trigger. Now to get my list of changes together.
Been trying that since September but Ford can't figure out how to get my info from where I uploaded my stock brain(Ford cloud) back onto my tuner! They can't seem to figure out how to resign my info to the new programmer they sent!
So here is a page from the instructions on the Pro Cal 4. Most likely similar for the Livernois my touch calibrator. With that software on your computer you should beable to refresh your Pro Cal 4 and beable to revert back to stock with no problems.
RNS
Randy
Manitoba, Canada
2006 Chevy Silverado,2011 Kia Soul,2016 Ford Transit 250,2016 Focus RS,soon to be 2020 Ford Ranger
Again been trying all this for months and the problem is on Ford's end! They can't figure out how to resign all my original files to the new pro Cal they sent!
Try all this every weekend and they've still got no files for me to download!
Just gotta wait till they figure it out!
Wish they would've used Cobb accessport as it was zero problems on my RS!
This was email from Ford 3 months ago!
Second, our engineers are working on getting the stock calibration “assigned” to your new tool. They are experiencing some difficulty at the moment, because the original stock file was already assigned to your stock tool, and they have never had to “re-assign” a calibration before, so they are having a bit of difficulty. They will get it accomplished, and it will be all set for you.
RNS
Randy
Manitoba, Canada
I want my climate controls back LOL
All this is going to do is refresh your Pro Cal 4. The stock tune is on your profile for as we speak. If you can connect your profile for to the computer just to refresh it it should allow you to use the touch screen with no problems and then you can go right back to stock with no problems. The file should be on your Pro Cal 4.
RNS
Randy
Manitoba, Canada
Will try yet again this weekend when I get home. My trucks 2 hours away all week and only see it on weekends. LOL
At this point it was in Ford's hands.
RNS
Randy
Manitoba, Canada
well yet another month with NO tune to download!
micl9
Apex, NC
2019 Ranger XLT Fx4 302A
Hey All
Does anyone know if there is a way to control the Aux Power plug behind the rear wheel? I was going to play around with the Dash Power point settings, but knowing the Aux Power is on its own fused circuit I am assuming it is not common to the Power Point settings.
I am looking to control both time on and "on trigger". Right now it only comes on after the ign is on(or truck is started, cant recall which). I would like to have it come on when I unlock the truck with the remote.
jubalr
Jubal
Winchester, TN
2019 XLT Sport
Having an issue finding the right values to put my climate controls back on the Sync 3 8" screen. They have disappeared and I bought forscan to put it back, but the values I have seen on YT are not working. Searched here and see where people have successfully restored climate controls, but not with the exact values to change. I appreciate any help. 2019 Ranger Sport. Thanks
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
You can do this without editing the HEX values directly.
In the same module (the as-built section) you can edit them as toggles. I don't remember which module it is off-hand, but I believe it's the APIM.
You should only need to edit Climate Domain to enabled (you can do the others as well but they don't appear to have an effect).
codestp202
USA
Ranger
Quick question for you guys, I did some forscan modifications. Everything went great, but something new has popped up. When I start my 2020 XLT 4x4 now, a little seatbelt screen pops up on my center screen on the cluster telling me what seatbelts are belted and I have to hit OK to make it go away.
I'm assuming I did this in the IPC config.
IPC changes:
Offroad screen / gauge enabled
Frost warning enabled
3 do do do's disabled
Terrain selection for TM enabled
I do not recall making any other changes. I took a backup and reverted just the IPC module which made it go away. I made the changes again and I notice the popup is there again. I was much more careful about my changes on the second go-round, and I know for a fact I did not enable any additional changes.
Any idea what IPC value might have turned this on?
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
IPC changes:
Make sure you do the "initialization" or whatever it is after you make the changes, it "writes" things to a more permanent state and should do it. I used to get something similar until I did that and a key cycle a few times.
codestp202
USA
Ranger
Interesting. You're referencing after you make a "write" the cycling of the ignition on and off correct? I made sure to do that each time. Wonder if I missed it once?
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
No, there's one more "special" instruction to do that writes the configuration values to the PCM so they're "constant" and not "out of sync" with what is expected. I can't remember what it's called offhand though. It's something along the lines of "re-initialize" or something.
micl9
Apex, NC
Just to fill the data base for Hex codes
Corner Light Mode for Fog Lights is
BCM 726-26-01 xxxx x*xx xxxx 0=disabled, 1=enabled
