FORScan Crowdsourced Wiki
I"m pretty sure these are one the main screen in the newer versions of FORScan - you don't enter any codes, you just select which mods you want to do and it will do the codes behind the scenes.
Now that you mentioned this...when I first dived into the forscan I got an interface that did have options to set active/non active...then the second time I went in, it was different as in it was as like a spread sheet that needed me to made changes to the code...anyone have this experience?
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
Click said tabs that do not say asbuilt.
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
How do you go back to as built?
IdahoRanger
Idaho
RETIRED
If you read the how to on FORscan, they explained on how to create .abd files of the original for safety's sake.
Thanks, everything is working ok just somehow added navigation to a non navigation system on screen and can't get rid of it.
Solved: Saved the backup just couldn't figure out how to go back so went in individually and reverted back to original settings.
orangegrower
AZ
2019 Aston Martin Vantage - 2019 Shelby GT350 - 2019 Ranger Lariat
I would assume he is talking about reverting back to as built after making mods but without having made backup copies before doing so. You can go here https://www.motorcraftservice.com/AsBuilt and get all your as built files. Then I am pretty sure you can use those files to revert back to the stock as built configuration.
Bproctor
Bruce
Hickory, NC
2019 Ford Ranger Lariat 2WD
NC National Guard
I just downloaded my as-built while waiting on my ODB2 scanner to come in. Prime 7 day delivery... LOL. Don't know if it will help anyone or not but if it does, good deal.
SubVet
Myrtle Beach
Where is the fix for missing climate screen on Lariat. 3.4 Version
Bproctor
Bruce
Hickory, NC
NC National Guard
Did I miss this?
RCMUSTANG
Chimes Vehicle Running Door Open Disabled
In IPC Module Configuration
Can someone point me to the code? Thanks...
Dslip
Vail, CO
2019 Ranger, Lariat, FX4, Shadow Black
Is it possible to disable the auto door locks? Did a search but didn't find anything.
thanks,
thanks,
You mean after the truck start moving? That's in your vehicle setting, left buttons on steering wheel...
Did I miss this?
RCMUSTANG
Anyone?
