FORScan Crowdsourced Wiki
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
Basically this.
You can test it for yourself if the fogs will meet your needs by turning them on. At the minimum you need an LED inside the stock housing. I usually used them most for cruising through campgrounds at night with headlights off to not blind people. Now they are also my DRL which I am so happy about.
Bambi mode will come in handy big time for me personally on dark highways.
Seconded bambi mode. I've had it on since I found it in FORScan. That extra light on dark backroads at night is hard to impress the importance of. It's so great. It does (at least for me) make the auto-highbeams a little wonky sometimes, but that's easy enough to override if it's a problem.
ControlNode
Eastern NC
Computers
I was thinking about doing that one day due to the narrow light output from the halogens, but the new LED lights cast a very wide output, about as wide as the DD Elite fog lights. even the high beens have a very wide pattern to them.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I tried LEDs in the halogen housings, not a fan. They're far too scattered and blind everyone and I hated the lack of any cutoff they had. That said, I upgraded to the Alpharex housings when they released and their cutoff and pattern is really good, almost 4 years in and still one of my favorite upgrades.
I'm interested to see how Ford improved them on the 6th gens, there was so much room for improvement.
ControlNode
Eastern NC
Computers
I would never use LED in a halogen housing I went with the Anzo LED headlight assemblies. I would have looking more that the AlphaRex LED headlights, but they refuse to get rid of that side marking in the housing that is not required.
If I'm not mistaken, DOT requires some sort of front side marker light on vehicles. It's up to the vehicle manufacturer on how to implement that. I remember my old 1993 Pathfinder, 1990 S15 and my Grandpa's 1993 F150 having them septic the Headlights, but that was then.
That said I also remember the Ranger having the front side markers on the fenders as well.
Gizmokid2005
GA
gizmokid2005.com
SQL Developer
I do agree, that's my one gripe about them, their color is off too comparatively. I thought about taking bulbs out of my fender markers but alas.
ControlNode
Eastern NC
Computers
Yes, DOT requires the vehicle to have them, does not have to be in the light housing, but if the OE light has it there aftermarket in most cases should too, unless they include a remote mounted side marker in their kit. AlphaRex when I called about that incorrectly stated that DOT requires them to put it in the light housing, but DOT doesn't care so much about the individual parts, and more about the vehicle as a whole meeting the requirements. But, they can count me as a lost sale now that I did buy a different LED headlight.
Jhbryaniv
2023 Ranger Tremor
Yes, DOT requires the vehicle to have them, does not have to be in the light housing, but if the OE light has it there aftermarket in most cases should too, unless they include a remote mounted side marker in their kit. AlphaRex when I called about that incorrectly stated that DOT requires them to put it in the light housing, but DOT doesn't care so much about the individual parts, and more about the vehicle as a whole meeting the requirements. But, they can't count me as a lost sale now that I did buy a different LED headlight.
It probably has something to do with they don't have to design a whole new pcb if they include it on every model they sell...
Thinking out loud maybe they have a single board and they program the i/o based on the vehicle and specific leds in each housing... Would make sense from a manufacturing stand point, at that point it's just programming it a little different...
mr_camera_man
Indiana
2021 Ranger STX 4WD Crew
I'm completely new to Forscan. Just ordered a cable and I"m going to play around with my '21 STX and my wife's '21 Bronco Sport as soon as it gets here. There's one thing I'd reeeeeally like to change but can't find a setting for anywhere. The excessively loud notification chime when using the Sirius XM favorite artist or song notification. Is there a way to keep the notification but mute it? My wife uses it heavily but it's banned in my truck because it's so distracting.
Hmm, I am not sure if this would tie in, but does the Bronco have Navigation?
You can adjust the (Navigation) Voice prompts when she is speaking (Turn Volume - Down) while she is speaking.
This should also be the case for (Voice Recognition) feedback prompts, when the Prompt is replying to your request (Play?) then turn the volume knob down, this will only adjust the volume level of that prompt.
mr_camera_man
Indiana
The Bronco has nav but my Ranger doesn't. I guess it's worth stalking for that prompt and turning the volume down, I don't think we've tried that before.
mr_camera_man
Indiana
OK so now I have the cable, installed Forscan, and I can't make any changes. Any change I try to write causes error "service procedure has been interrupted."
Forscan 2.3.65 with trial extended license (is that the problem? is the trial restricted to read-only?)
Tried with several different changes including panic activation, auto stop, and hyper blink, in both GUI and as-built mode.
Godiag GD101 with latest drivers installed from their website. Bought this cable because it does both J2534 and EDM327. Same error in either mode.
Any thoughts?
twk
Tom
Minnesota
'17 Mustang GT drop top, '22 Ranger Lariat Fx4 SCABbie.
Flight Simulator Engineer, retired, unemployed, burden on society.
Any thoughts?
What are you trying to change?
When I enabled "Parking Lights with Driving Lights" on my Ranger there was no problem. I liked it enough that I tried that on my '17 Mustang, and it came back with (I'm pretty sure) that same message.
(edit - fixed a format goof)
mr_camera_man
Indiana
At first I tried doing disable auto stop, disable hyper blink front and rear, panic mode 2x, courtesy wipe all at once. When that failed, I tried only panic 2x since that seemed innocent enough, and that failed both in GUI and as-built.
twk
Tom
Minnesota
Hum, worth mentioning I thought.
I've never been gutsy enough to do more than one change at a time, but it shouldn't make a bit of difference. And I never did get my Mustang to have parking lights with driving lights. I had to give up. ?
