FordPass Siri Shortcuts
Ugly_Betty
PNW
2019 Ford Ranger Lariat FX4
Is it possible to have a shortcut run after one is completed?
Example: after running "Lock My Car" have that shortcut run "Is My Car Locked?"
or "Start My Car" then run "Is My Car Running?"
You can edit the shortcut by adding an action at the end (plus button at bottom). I added Script>>>Wait>>>5 seconds, then APPS>>>Shortcuts>>>Run Shortcut>>select the Is my Car Unlocked shortcut. May have to mess with the wait time to see how your connectivity is.
Buddybiro
Buddy
2020 Ranger xlt
Which shortcut should I edit? where Exactly do I put that? Sorry I know nothing about this stuff and when it worked the first time I was excited enough to want it bad. Lol I did uninstall restart and install again a few times with no luck. thanks for the help.
Jon Olivier
Jon
Bishop, CA
Just re-asking question above
If you run "Get FordPass Token", "FordPass Settings", or "Get Vehicle Status" on their own, do you get an error?
onthejob
Bristol, NY
2019 Lariat, 501A, Spt Appearance, Tow, Fox Shocks
I couldn't get past run a shortcut once. I'm a level ZERO iphone user. So I brought the phone to and found a Millennial and it works awesome!
Buddybiro
Buddy
2020 Ranger xlt
I deleted my truck from FordPass and reconnected it and bingo it works. Thanks for all suggestions and help. If I have any problems I’ll let you know. I need to add the other commands now. THANKS AGAIN!
ChopprJock
Lyn
St. Louis, MO
2019 Ford Ranger Lariat, FX4, Sport, Tow Packages
Aero Engineer / Ops Analyst
This is an AWESOME set of scripts, thank you! Much faster than the FordPass app. I also like using the Dick Tracy option with my watch!
port43
Detroit Suburb
childrescuecoalition.org
Secret agent, man
Depending on how fast the path runs from your phone to Ford servers to vehicle and back to phone you might need to set a "Wait" in the scripts (if I didn't already include that before) before checking if a sent state has been processed. For instance I had to up mine to 10 second wait after starting and before checking if it was started to give it time to process.
Long time no see Tony...Good to see you back on here.
port43
Detroit Suburb
Secret agent, man
Sorry, I've been MIA for a bit; glad you got it functioning.
port43
Detroit Suburb
Secret agent, man
Thank you Sir. I was all caught up on my mods and now it's a beautiful day in the neighborhood so I'm spray painting my aFe.
Secousse
Secousse
CA
2021 Lariat Tremor
I’m so grateful for this thread - thank you OP!
port43
Detroit Suburb
Secret agent, man
port43
Detroit Suburb
Secret agent, man
Here's one to tell you how many miles (sorry metric world) you can go on the fuel left in the vehicle and is based on what the current value for average MPG of the vehicle. It too needs the initial "Get Vehicle Status" shortcut to run.
It is easily corrected for km by removing the conversion to miles step in the shortcut.
Nipperchipper
Lance
Saskatchewan
2019 ranger lariat
Some geniuses over on reddit have figured out how to get Siri Shortcuts working with the FordPass app so you can tell Siri to start your truck, stop it, unlock it, lock it, check the fuel, oil etc. Ive installed the shortcuts and tested them all out on my device and they are working perfectly.
If any of you don't know what this does or means, it means you can control your truck by voice and don't need to open the FordPass app to to do any of the above mentioned commands. Something I've been waiting a loooooooong time for that Ford will likely never bring us.
On your phone, you need to go to settings>shortcuts> toggle "allow untrusted shortcuts" on.
Also, I had to change the wording from "Car" to "Truck" on each shortcut because Siri wouldn't run the command using "car"
Link to instructions:
This does work in Canada
