Ford Performance Tune - Update
LoneRNGR
Lubbock, Texas
2020 Ford Ranger XLT
Systems Engineer
When you update your tune, do you connect a battery charger and if you do, are you doing it right?
bearrug
Idaho
2021 Ranger STX 4X4, 2023 ford Bronco Sport
When you update your tune, do do connect a battery charger and if you do, are you doing it right?
I never hooked up a battery charger if your battery has enough juice in it you should be fine also the process didn't take all that long to do.
Rp930
Rp930
Denver
I did the first time but when I installed the update I skipped it. I would make sure I drove it recently just to be sure the battery is up.
EDITED: The tuning process doesn’t take long. 15 minutes or so.
LoneRNGR
Lubbock, Texas
Systems Engineer
I would make sure I drove it recently just to be sure the battery is up. It doesn’t take long. 15 minutes or so.
Driving for 15 minutes will not necessarily charge the battery at all. The Body Control Module charges the battery only when it is economical to do so. This is why charging a battery using the negative battery post will trick the BMS into sending inaccurate information to the BCM. I am thinking that you could unplug the BMS while charging, but I'm not sure I'd want to try that while doing a tune update.
Rp930
Rp930
Denver
No, I meant the tuning process takes about 15 minutes. Not drive it for 15 minutes. Sorry for the confusion.
Buffy Blue
2020 Ford Ranger XL Supercab
Agreed, my first install saving the stock tune to the PROCAL took over 20 minutes. It was worth buying a $20 tender...ya don’t want that process interrupted!
lawrench
Harry
2019 Ford Ranger Lariat SCrew FX4 Lightning Blue
So, like others, I noticed that there is a mount. Does the tablet/pad that comes with this have to stay connected and thus a mount is needed?
Rp930
Rp930
Denver
No you don’t need it to be connected after tuning.
Buffy Blue
Nope, no need, if there was some info like boost gauge, air fuel ratio or the like I’d keep it on. I’d rather not attract attention and am not inclined to run that cord through the dash or vents.
Rp930
Rp930
Denver
cbull
Curtis
Idaho
2020 honda civic hatchback CVT 2017 ram cummins
Farmer
Why pay for ford tunes rather then tunes from a company like livernois, or 5 star? Just for warranty reasons?
Chattownranger
Chattanooga
2020 Ranger
Mechanic
My update looks different
2020 xlt 4x4 supercrew
Mine is exactly the same as yours and I have a 2020. Maybe that’s it? Haven’t driven yet. Just flashed it and now going to bed lol
Michael
New Hampshire
2020 Lariat FX4
Really considering the FPP tune as opposed to Livernois. Have you guys noticed an improvement with downshifts as well?
