EGR DPFE Sensor Assembly Replacement Write-Up (LB5Z-9J433-B)
TJC
I got an intermittent check engine light, checked the code with torque & it was a P0113. This started in Sept, so today I went to dealer thinking it was emission related. They had a different code, which
was for DPFE. They want 5 hrs labor + parts, 60k mile truck. So that's over 1,000$ Canadian, which comes to, what half that US?
No other issue with truck, no other symptoms.
Anyway, Rock Auto it shall be.
How do they figure 5 hrs???
Same dealership I got the transmission updated with a TSB & they wanted to charge me when it was still covered with warranty.
Do they wonder why we call them stealerships?
$18 USD and an hour of your time will correct it. Next time around will be a 15 minute effort.
CB750F
Qc
Human
Yup. just changed my water pump on a 2007 Escape, what a pain but fairly easy, I'm just slow now.
Too bad it's 32f & not getting warmer, I hate working in the cold.
Tks @Trash Panda for the write up, much appreciated.
Trash Panda
Trash Panda
Cody
Anytime! I always try to do a write up for anything I encounter that is not readily available on YouTube, etc. ??
TJC
"In a world where you can choose to be anything, choose to be kind."
I saw your signature statement and felt compelled to reply. Your statement touched my heart.
Nature abhors a vacuum. In a world of good and evil, my wife and I decided when we married to fill that void with goodness. We vowed to do something kind once a day for those we come in contact with.
I salute you sir for your choice. God Bless You and Merry Christmas!
Arsenal741
Matthew
2020 Ford Ranger XLT FX4
Project Lead
Kudos and Thank you for this write up and to this forum. It cannot be oversold how big of a difference swapping this part out can make. I have 90k miles on my 2020 Ranger and had noticed slightly rough shifts, searching for gears at lower speeds/rpms for the past 5k miles. Not to a level of large concern nor was it lighting up the dash with codes, however I decieded to buy this sensor and replace moreso from a preventative mindset. Once installing it was evident within the first shift the change. I had clearly gotten used to the rougher shifting which likely became worse over time creating the new normal to me. It darn near feels like its a CVT with how smooth it is now. haha.
TJC
I think a lot of people simply adjust to the rough shifts thinking it is normal. Changing the transmission fluid, and adding LubeGard Platinum cured 99% of my issues.
Changing the EGR DPFE sensor took out the rest....which is my case was almost nothing more than an annoyance compared to what was happening before the fluid change. My transmission is behaving normally again. And I am only at 25K miles.
Ironman
Bill
2023 Ranger XLT, 2017 Jeep, 1969 Plymouth R R
Retired Ironworker
Just had my 2023 XLT in for this same sensor replacement and CEL came on at 19,000 miles.
Just a small Ford dealer and service department and I know all the guys there and I asked is this a common problem and Kenny looked at me said like to have a dollar for all that I replaced so far.
Told me water kills most of them.
CB750F
Qc
Human
Still looking into this but the price makes me shake my head...
KA1Z5L200A from dealer is 152, but rock auto is 23$ - No hoses.
LB5Z-9J433-B is 173$ - With hoses.
What am I missing here? Is it a problem removing/reinstalling the hoses on the DPFE?
Anyway, no rush for me as the CE is no longer on & no transmission issues, I'll be changing it
in the spring when I won't freeze my fingers.
TJC
Those are expensive hoses at $150! Seriously the sensor is all you need to replace.
Buy a couple of hose clamps from amazon or where ever, and use the old hoses. There are dots on the hoses , be sure to align them to the front, and move the hoses one at a time to insure you put the correct hose on the correct barb on the sensor. The hoses are different. Pretty easy job.
The two clamps on the sensor end of the hoses are not reusable. The other two hose clamps are spring friction fit and they will come off easily with needle nose pliers. Buy 2 or 3 of the sensors and stock them away. The next time you change the sensor out will be a trivial effort and take you 10 minutes.
Maverick8054
Ranger 19
Just replaced this sensor with the one linked. Unfortunately, still have the same issue around gear 3,5,&7. I also reset the learning table and ran through the gears and did the little re-cal cycle x6. Any other suggestions?
TJC
Change your fluid and add LubeGard Platinum. It cured my crazy transmission issues when nothing else would. It is cheap and you have nothing to lose. I let the truck sit overnight and got out 7.5qts. I added that amount back in leaving room for the 15 oz of LubeGard. Problems were cured immediately with a small slightly harder shift from 4th to 5th. Drove it a week and repeated the process, This time it was smooth as butter. It is time to change the engine oil and I'm going to repeat the process one last time. This will get me to 87.5% new fluid with LubeGard going back in again. I am then going to try for 25K change cycles. So next one will be at 50K unless I start seeing shift problems again.
just be sure to replace exactly what you suck out via a transfer pump. I've got 8K trouble free miles after having 10K-12K of increasingly bad shifts, jerks, slow shifts, and hard stops. First was barely noticeable, but the problem only became progressively worse.
Stevedbvik1
2022 Ranger Tremor XLT
If you’re within the 5 years/ 60K miles power train warranty take it in to your dealer for TSB 24-2101. If your not then what @TJC suggested would be a good next step.
Dayton86
Josh
NorthWest Mississippi
2020 Ranger
Water Treatment Operator
Thanks for the write up, and i got mine done today. On the 15 mile test drive after the truck was like new again. Highly recommend this being done and will order another one soon to keep on the shelf as they seem to have trouble keeping in stock.
Thanks again.
Arccra12
Christopher
2021 Ford Ranger XLT
IT technician
2021 Ford ranger XLT with leveling kit 80k miles.
Should we be disconnecting the battery before we start this? I did not see this instruction. Even though its a easy swap pending maneuverability I am reviewing just in case. I am having the bucking between 0 and 25 intermittingly. Some mornings it is fine until later in the day. Lately it seems a little worse. I have 80k miles on this and outside of changing the rear brakes I have had little to no service needed. Full synthetic oil changes, cabin, air filter, and tires is about all that it has ever needed. Tried to get a 60k miles service and ford inspected and sent me away with no charge saying it is in great shape and nothing is needed. I will be taking it back to attempt service soon again. I am thinking of a tune up to be save but likely need to get the service done.
I am swapping just the sensor in which I purchased from rock auto for 45 bucks after shipping(a week late). I plan to cut the crimp clamps, remove sensor and replace with screw clamps.
-Part from rock auto was labeled vs1 but had proper numbers for the oem part on the picture. When I received it the top part was rubbed out and almost looks like it was refurbished. Fingers crossed it is fine. I would have purchased the whole assembly but I am concerned reaching the bottom part of the hoses. I will try to update how things go.
Trash Panda
Trash Panda
Cody
I did not unhook my battery when I performed it and observed no ill effects, good luck!
