EGR DPFE Sensor Assembly Replacement Write-Up (LB5Z-9J433-B)
What was the code you had?
and
What was the DPFE sensor reading (Live Data)?
or was this a blindly changed shot gunned part?
Generally, the associated codes for the DPFE - P139A - P139B - P139C and P0401 - P0402 will clear on their own after 3 drive cycles with EGR events - (light will go out) and 40 warm up cycles to fully clear from history.
I am about 90% complete on my EGR System operation guide - so posting soon.
Since you didn't quote, not sure who your question is addressed to.
Is there @ny sort of code reset or is it pretty much just plug and play reset?
and
and
I don't think he had any codes, he was just inquiring further into the DPFE thing in general after I brought up.
Mike1
Ranger XLT SPORT
Shout out to Trash Panda. Great write up. I have a 2019 that has been running like crap for months. I ran across this thread and ordered the replacement sensor from Amazon. The ad did not show a brand but when received, it was Branded FOMOCO, Malaysia just like the original. I shredded my arms trying to get the lower lines off but nothing a few band-aids and time won't fix. Anyway, The result is fantastic. This simple fix made an unbelievable difference in the way my truck drives now.
Big thanks to everyone who has added to this thread. I was able to glean A LOT of very useful info from this thread alone.
Mike1
Mike1
I had about 75k miles on mine when I replaced my DPFE sensor. I had no real reason to replace it, except for a couple weird shifts here and there. After I replaced it, I have noticed no noticeable difference, but perhaps maybe the slightest improvement is overall performance.
Sabertooth
Northern Virginia
2019 Saber Lariat
I have around 86k and had just gotten used to a few hard or delayed shifts when I first started out or an occasional slow or hard shift in day to day use. Saw this thread while trolling and thought I would give it a try. NIGHT AND DAY! I forgot how smooth this truck could shift. It truly feels like a new truck and I had the trans service done at 75k with no big change in performance. Thanks for this post.
lariat
Western US
Ranger Lariat
student
I purchased a new sensor 2 years ago and haven't installed it yet, but need to. I'm always worried I'll mess something up and will be left with a truck I can't drive even though I'm mechanically inclined but it's such a tight area to work in.
Trash Panda
Trash Panda
Cody
I purchased a new sensor 2 years ago and haven't installed it yet, but need to. I'm always worried I'll mess something up and will be left with a truck I can't drive even though I'm very mechanically inclined, race bikes, etc, but it's such a tight area to work in.
Don’t overthink it ; just take it slow and follow the instructions. The hardest part is taking the hoses loose and the trick is to be wearing a headlamp for visibility and use one hand to compress the clamps with your pliers and the other hand to pull the hose to the right!
TJC
It is one of the easier parts to replace (just the sensor). And once it is done, the next time you need to do it will require only 10 minutes. No need to pull the hoses, just the sensor... which is almost trivial.
Pull the sensor and the hoses the first time around, replace the sensor reusing the original hoses. Use small replacement hose clamps on the sensor hose connections, and orient the clamps head so they easily reached with a nut driver. Easy Peezy!
I'm 5'8" and needed a step stool to reach over the engine to get to it, but I need that step stool to get to most anything under the hood! Even adding/checking the oil! :LOL:
CLopey
Christian
Los Angeles
2019 Ford Ranger XLT
Coach
Greetings All,
Dropping another one of my write-ups on the infamous bucking/surging epidemic our Rangers seem to have.
Check out the "Bucking/Surging Epidemic" thread started by @Tim Vogt Sr. for every piece of information you could want.
https://www.ranger5g.com/forum/threads/bucking-surging-epidemic.14581/
There are two ways to do this job, simply the replacing the DPFE Sensor itself (Ford KA1Z-5L200-A or KA1A-5L200-AB) or the entire assembly (Ford LB5Z-9J433-B). This write-up is geared towards replacing the entire assembly.
My symptoms were prevalent in the low RPM and low speed range. I drive like a peepaw and slowly pulling out of my driveway I would get a "misfire" feeling but no check engine light. I did my plugs last week so an actual misfire would be highly unlikely so my next step was the DPFE sensor. The transmission would search for gears at low RPMs and sometimes it would feel like driving a manual in too high of a gear through my neighborhood.
Supplies Needed :
-DPFE Sensor Assembly (Ford LB5Z-9J433-B) ($97 on @LevittownFordParts.com)
-3/8" or 1/4" Ratchet
-8mm shallow and deep sockets
-1.5" extension (if desired)
-Torque Wrench set to 97 in.lbs
-Needle Nose Pliers
-Straight-Jaw Pliers (I used my Milwaukee 6" 48-22-6306 pliers)
-LIGHT (Headlamp, Milwaukee Rover, etc)
-Work Platform or Step Ladder
Step One :
Pop the hood and locate the DPFE sensor. It is located near the back side of the engine on the driver's side of your Ranger near the brake booster.
STEP TWO : (*You could swap this with Step Three if desired)
Use your Ratchet and 8mm socket to loosen the single mounting bolt on the top. A deep socket is perfect for this without the brake booster being in the way.
Once you loosen the 8mm bolt, you can easily unthread it all the way using your fingertips to reduce the chances of dropping a socket or the bolt in to the engine bay.
*NOTE there is a washer with the 8mm bolt so be sure to not drop it.
STEP THREE : (*You could swap this with Step Two if desired)
Remove the connector from the DPFE sensor. If you read my Spark Plug write up, the connector works just like the coil pack connectors. Use your fingernail to slide the locking tab out (circled) and wiggle the connector off.
You can hang the connector out of the way on the metal line in the top right of the photo below to prevent damage.
STEP FOUR :
With the DPFE sensor unbolted and unplugged you can pull it out of the way to give you room to access the spring clamps on the hoses. This is where having a light is necessary. Take note of how the spring clamps are oriented. Mine were both facing relatively face-up. Removing the clamps is the most difficult part of the job so just stay calm and take it slow. I started with the shorter hose first to give me more leverage on the longer hose.
STEP FIVE :
Start with the smaller hose (closest to you) and go straight down with a pair of needle nose pliers (longer ones seemed to work better). When I pinched the spring clamp and pulled up the hose came right off. I did not have to fight it at all. Once the hose is off you can also place it to the side or out of the way to give you the most access to the long hose.
STEP SIX :
Remove the spring clamp on the longer hose (furthest from you). What worked for me was compressing the spring clamp, pliers in my right hand and pulling the hose horizontally to the right with my left hand. The DPFE sensor is now fully removed.
STEP SEVEN :
Reverse what you just did in Steps FIVE & SIX and take the new DPFE sensor and slide the long hose(Furthest from you) (yellow clip) on first and the short hose (closest to you) (white clip) on next.
Align the spring clamps facing upward as much as possible to make the job easier the next time you have to potentially perform it.
When the hoses are pushed on as far as possible twist the yellow and white clips clockwise to remove and engage the spring clamps.
STEP EIGHT :
Re-mount your new DPFE sensor using the guide pin and hand thread the 8mm bolt until snug to prevent cross threading. Take your torque wrench set to 97 in.lbs and torque the 8mm bolt. (It takes no effort at all and should click in a second or two)
STEP NINE :
Reconnect the DPFE connector. Slide the connector on until you hear a "click" and use your finger to engage the white locking tab by pushing it from the back towards you.
Crank your Ranger to see if a check engine light or any error message appears. Take a test drive around the neighborhood to see if there is an improvement in the surging/bucking in a low gear. I noticed an instant improvement on my Ranger and it drives like a brand new truck. Time will tell how long the replacement lasts.
That's it! Grab a cold one and enjoy a job well done! :sunglasses::beer:
Yet again it took me longer to write this write-up / take pictures than the actual job did. I would say it is a 30 - 45 minute job as long as you do not lose a socket or bolt in the engine bay. :crackup:
Thanks for this! Going to do it later today. Hoping it resolves the bucking.
Do you have to adjust anything with Forscan after installing new sensor?
Trash Panda
Trash Panda
Cody
I do not have / use Forscan so I do not think so. I did not even unplug the battery and it still made a pretty instant difference.
CLopey
Christian
Los Angeles
Coach
Okay cool. Thank you very much.
lariat
Western US
Ranger Lariat
student
The only correlation is water content.
DPFE - Moisture Content - in the exhaust (natural product of combustion) over time damages the internal sensing membrane on the circuit board, giving erroneous false readings and allows the EGR Valve to open when it should be closed. This is the Buck/Surge as the engine is stumbling from the extra fuel vapor being introduced from the opened EGR Valve at low RPMs.
Plug Well - Water accumulation - Watershed runoff from the windshield runs down into the plastic cowling along the bottom, depending on how the truck is parked (nose down) its more prevalent water drips off of the cowl right above #4 Plug, water will follow the path of least resistance and pool up at the #4 plug and seep down into the well past the COP Boot, it also has been known to travel down the valley and pool up at #1 plug as well.
Congrats on getting the broken plug out, I know that was a heart sinking feeling of Oh-Crap.
What type of Easy Out did you use or make?
The addition of the Engine Appearance Cover - Helps SOME but does not eliminate the root cause.
So, some have sealed the cowl area or added a divertor modification to drain any rainwater away from the top of the engine
" DPFE - Moisture Content - in the exhaust (natural product of combustion) over time damages the internal sensing membrane on the circuit board, giving erroneous false readings and allows the EGR Valve to open when it should be closed. This is the Buck/Surge as the engine is stumbling from the extra fuel vapor being introduced from the opened EGR Valve at low RPMs.
Plug Well - Water accumulation - Watershed runoff from the windshield runs down into the plastic cowling along the bottom, depending on how the truck is parked (nose down) its more prevalent water drips off of the cowl right above #4 Plug, water will follow the path of least resistance and pool up at the #4 plug and seep down into the well past the COP Boot, it also has been known to travel down the valley and pool up at #1 plug as well."
I'm picking up your post late, but replacing this sensor just opens the possibility/likelihood this will just keep reoccurring, no? Assuming everything you wrote is accurate (which all seems fine to me), the notion of water accumulation seems inevitable over time.
Curious to hear your thoughts.
TJC
One has absolutely nothing to do with the other. The water destroying the sensor is coming from condensation from the exhaust gases. Best to consider the part as a wear item. Dryer climates should have less of an issue.
This is my understanding...
