Check Engine Light - 5600 miles - Code: P02EE
Fordman
Richmond, VA
2019 Ranger 4x4 CC
Instrument Tech
Mine is doing the same thing only worse. Do not switch to 93 octane as this issue only gets worse and still doesn’t give engine light.
Mine is going in this weekend with the blessing of Ford corporate to do diagnostics beyond the “ their is no code”.
Call ‭(800) 392-3673‬ (be patient, they are nice but deal with a lot of jerks. Don’t be one) and get a ticket started. The more they hear about this the sooner it gets taken care of.
Mine will be in for a few days but I’ll post the findings. Good or bad.
Have you gotten any resolution on this issue.
? I have the exact problem since day one.
kieefer
keith
2019 2WD SuperCab - 97 BMW M3
How is yours now is the issue still gone?
I have the same exact issue. No CEL rough around 1500rpm ususally in a gentle cruise like through town. 4 days at dealer and they did nothing except tried to blame it on Tranny and updated tranny profile. Has nothing to do with Tranny since I can lock it in 7th or 8th gear and it will still do it. Rarely I can even feel it at idle on cold start. I am very hesitant to waste my time at dealer again.
Still got it. Sometimes intermitting.
I think it’s a faulty fuel injector.
I did read on here that a fellow found a bad spark plug. Considering looking at that but haven’t had time.
Fordman
Richmond, VA
2019 Ranger 4x4 CC
Instrument Tech
Plugs and coils were the very first thing I checked. I looked at gap, isulators, and actually swapped coils from 3 to 1 and monitored. The reason is that the on-board monitors picked up misfire on my scan tool but not frequent enough to set CEL. Random misfire sometimes cylinder 3 sometimes 1 or 2. The issue can also be caused by lean condition possibly a bad injector like you mentioned. I did see one guy had same issue but got CEL and it turned out to be bad injectors. Guess the trick is to try to get Ford to look beyond the CEL. No new vehicle should run rough and Jerk like mine does at low speed.
acsnowrider
JOHN
FL
2019 RANGER XLT
RETIRED FORD ELECTRONIC/DRIVEABILITY TECH
Seeing issues here, with no MIL/CEL--
Have any members considered the below TSB for these "misfires?" Member thread/issue link!!!
https://www.ranger5g.com/forum/threads/tsb-19-2052-april-2019-build.6475/#post-115717
Tcskeptic said:
FYI — after a little back and forth and opening the concern number they put the Ranger on the computer and detected a number of misfires. They applied TSB 19-2246, picked my truck up about 10 minutes ago, we’ll see how it goes. Thanks again for your help.
TSB info--
https://www.ranger5g.com/forum/threads/tsb-19-2246-2-3-ecoboost-misfiring.6709/
FX4Offroad
South Florida
2019 Lariat FX4
I have an intermitting stumble/roughness at 1500 that I think possibly is a fuel injector, if one can be intermitting? No CEL, ever. 12k miles.
Runs worse on 87, best with 90. Sometimes it appears damp weather makes it worse.
Tried a tune from SCT Bulldog but no different, just went back to the factory stock tune and it’s running great. Go figure.
Mine is exactly the same except I never tried a tune.
acsnowrider
JOHN
FL
2019 RANGER XLT
Ran into this so many times with Ford!!! :question: Software download integrity marginal on first attempt--I reloaded/or updated software, and issues resolved!! Just resetting the "adaptive memory" at times eliminated the issue!! What they are putting into these PCM's, not only to run our vehicles, but to protect from "reverse engineering" is extremely sophisticated!
kieefer
keith
As mentioned I’ve tried a tune, no change but again it’s intermitting. Seems worse on damp cold rainy days.
Mine doesn’t jerk but if I put foot in it from a stop, AS IF GETTING ACROSS FOUR LANES IN A HURRY it’s slow to respond, almost a full stall.
The missing is easily erased by getting past 1500-2000 rpm. Sport mode keeps the revs up and it’s not as noticeable.
A real annoying pisser.
kieefer
keith
You referring to the stock tune??
How can I try this??
Sako887
Sarkis
Los Angeles
Subbed. Having a similar issue, no cel but at times recorded 10 misfires in 30min. Usually cyl 1, 3 sometimes 4. Stumble between 1800-2300rpm under acceleration.
acsnowrider
JOHN
FL
2019 RANGER XLT
The member, listed below, stated in this thread, he had a "unable to duplicate/NPF" during this event!!!!:) No indication on the thread, that the CEL was on!! Just "misfires"!!
acsnowrider
JOHN
FL
2019 RANGER XLT
YES--
Read the above listed thread--Phil, has a VERY good suggestion to move forward on a difficult diagnoses/fault pin point. :like: Posting #2.
Racket
Here and There
2019 Lariat Supercrew 2WD
Transient
I have been running 89 as well. I'm having a hard time finding forums on what fuel most people are using. Do you plan on sticking with 89? Could this potentially harm the engine since it is tuned to 87? If anyone knows the answers please feel free to let me know. I keep going back and forth about whether I should use 87 or 89.
Gas prices have been low, and I indulged in filling up with high octane. Checking my gas mileage, still not a huge improvement for the $$ and I'm still not convinced the performance is dramatically higher... but I'm running almost all stock (exhaust upgrade and a GFB valve on the blowoff). I've been following threads on ECM mods and am thinking that may be the next tweak. As far as the stumble, I'd prefer to try something simple the first time around to improve the low speed experience. If there were truly a cleaner/lube for the injectors it would be worth a try. Back in the day, Seafoam was the cure-all for all kinds of crud.
Edit to add: if I go shopping for injector cleaner, this ad/post suggests a PEA-based additive is the place to start: https://www.roadandtrack.com/car-culture/a4848/sponsored-content-fuell-additives-reality-vs-fiction/
kieefer
keith
I mentioned above about mine running rough in damp wet weather.
Today it’s 80 and dry, ran like a top...?‍♂
Fordman
Richmond, VA
2019 Ranger 4x4 CC
Instrument Tech
Dealer told me that they drove my truck and verified it, but considered it a normal charachteristic of the 10 speed, saying that it gets kind of "confused" on whether to shift or not. They didn't even hook up the diagnostic to check for codes or monitor anything. The good news is I'll save the money on the Ford protect plan I was going to purchase since I can't get anything that requires a little bit of effort fixed. No sense in paying for a warranty when everything is "normal". This is the 3rd dealer I have tried. In fairness the 2nd dealer never returned my call after being on hold for 10 minutes and leaving a "detailed message for one of their service professionals to call me back as soon as possible".
You ever get anywhere with this issue? I was told the same thing about the tranny. I don't buy it since I can manually lockout gears and still does the hesitation and jerk at low speeds
Fordman
Richmond, VA
2019 Ranger 4x4 CC
Instrument Tech
You can run the higher octane no problem it will harm nothing. The 87 is actually the minimum octane and recommended. The ECM will automatically compensate timing curves for octane
