TSB 19-2052 April 2019 Build
Tcskeptic
Rich
Waco, TX
2019 Ford Ranger Lariat, 4x4
I recently bought an April 2019 build Ranger. It seems to exhibit the symptoms of 19-2052. It jerks and lunges at low speed when cold, jerks when accelerating when cold and lunges and feels like it is stalling out at low speed. Overall, it is really detracting from the truck. I took it by the dealer but it was both a warm day and took me 1/2 hour to get there so the symptoms were minimized. Based on my build date they declined to do anything — what should I do next?
HI Rich,
File a complaint with Ford Customer Service. Generate a concern number. The the dealer has something to which they can charge their time and money... You will have to elevate this above the call center in the Philippines. Insist to talk to a US based Customer Service Rep.
Tcskeptic
Rich
Waco, TX
HI Rich,
Thanks Phil — I will start that direction
Tcskeptic
Rich
Waco, TX
FYI — after a little back and forth and opening the concern number they put the Ranger on the computer and detected a number of misfires. They applied TSB 19-2246, picked my truck up about 10 minutes ago, we’ll see how it goes. Thanks again for your help.
VAMike
2019 Ranger Lariat SuperCab
HI Rich,
How can the dealer charge Ford for performing service applicable to builds before mid-March for a truck built in April?
Sako887
Sarkis
Los Angeles
Any updates on the truck? Did that tsb fix the issue?
TrebMaxx
Robert
Mid MO
2019 XLT FX4 Ford Ranger
April build here too. Following.
Tcskeptic
Rich
Waco, TX
I have not put nearly as many miles on my truck over the last few weeks due to WFH, but I made it a point to go driving on a few of the very cold mornings that we have had. As far as I can tell, things are 99% better. The only thing I think I detect at this point is a stutter on hard acceleration while still cold. But it is a vast, vast improvement.
a andrews
ALAN
FORT LAUDERDALE
2019 RANGER XLT
RETIRED
hi- just to followup- i have a build date of 4/2019. had identical issues. after 4 trips to ford the shifting problems left , but still excessive hesitation/ jerking or studder from when engine is cold until completly warmed up is present. finally did the 19-2052 or the19-2246 fix your problem? thanks alan
Tcskeptic
Rich
Waco, TX
19-2246 fixed it. There is still some hesitation under hard acceleration as I mentioned above, but it’s not major enough for me to care about.
alan andrews
alan
2019-ford ranger xlt
i think you just solved the problem. ill present this to ford care and make sure they direct the info to the local clueless ford dealer. THANKS!
