Porpoise Hork
- Thread starter
- #1
Recently I saw this panel between the cab and bed. It is a carpeted panel with a jute backer on it and extends the width of the cab resting on a lip extending out from the cab. The issue I have with it being there is not only does it trap leaves and other trash but more importantly water. Since this part of the cab it's sitting on is steel, it's only a matter of time before things start to rust. I searched all the available parts for the Ranger and cannot find this panel listed anywhere.
It's been raining off and on the past couple of days and there's a mildew smell in the truck when I first open it up. This has been a thing since I got the truck. On several occasions when the mildew smell is present, I have checked nearly every inch of carpeted area inside the truck after rain storm with a moisture meter and nothing. No trace of water inside the truck. When I crawled up under the truck today to inspect the panel and pressed on it, water poured out like squeezing a soaked sponge. I am convinced this is the source of the mildew smell since it sits directly below the pressure vents on the back wall of the cab.
I can't see any way to get this out from below the truck since the lip it's sitting on does not allow much room to shift it as well as the parking brake cable assembly, drive shaft, etc being in the way. Once it dries out, I may be able to use a fishing hook or something to grab it and lift it out provided it's not secured by anything. Does anyone else have this panel sitting here? If so why would Ford think it would be a good idea to put something like this there and create a corrosion issue.
