Biggest tires, no lift?
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
I removed the crash bars, cut the brackets, stretched and trimmed the fender liners and bent the core support.
I no longer have those tires though. I now have 285/60/18 and they don’t hit anything at all and are so much lighter.
Love the bronze wheels with the blue! Looks amazing! Thanks for sharing!
David530
Calaveras county, California
2023 Ranger XLT, 2002 Ranger Edge
Mechanic/ decal and logo designer
Not sure if you tried to post a picture but is was a blank reply lol
Wablackwell22
Andy
Columbia, SC
23 Ranger
Paralegal
What offset are your wheels? I'm about to order some 0mm offsets I know that theyll push the face of the wheel outwards about 2", just trying to get an idea of want to know what they'll look like actually on the truck.
Loweredon33s
Baltimore
2021 Ranger
Performance person
They are technically +30 but I also have a 30mm spacer which makes them effectively 0 Offset.
Cabose-1
Eli
Student
I saidbi would post here when i did this.
255/75/17
No rub! Ride is so much smoother too. Like a whole new set of shocks. Acceleration feels like a big truck. Fixed speedometer with forscan. All stock vehicle. Only mod is tailgate strut assist.
2022 xlt fx2
yuck6
Jack
New York
2020 Ford Ranger Supercab XLT 301a
Electrician
285/70/17, 2.5 level, removed crash bars and trimmed front lip, no rubbing
Could you post a photo of the trimmed front lip. Curious to see What you did.
David530
absolutely, I used my angle grinder and just followed the same shape the lip already had but just a little bit inward, I took off a little and went and drove around to see if it still rubbed and it did so I took a little more off now we should be good, just a little at a time, you can always take some off but can't put it back on, I don't think anyone is even gonna notice. After I was done I smoothed it out with a piece of sandpaper and it looks good I think!
PINKS
Perry
Canada
2021 Ford Ranger Tremor
Forestry Tech
We have 275/65/18....its a 32.1 inch tire....not sure what or if there is for offset....were installed by PO....I noticed that he did have to "modify" the crash bars!!???
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Very capable, good looking truck! I like the graphics too! Thanks for sharing.
NJSalt23
New Jersey
2023 Ranger XL Extended Cab 4x4 Shadow Black
Business owner
Unless I missed a part of the thread I don't see anyone discussing the largest tire size w/o modifications for 16" rim. My 2023 XL 4x4 Extended Cab has OEM Bridgestone Dualer HS in 255/70R16 and I need to move up to a true LT tire for moving heavy materials in the bed. From what my math tells me I can squeeze a 265/75R16, which averages 31.5" diameter, into the front well with at least .75" to spare. Is this the be size or is a 245/75R16 a better fit, which is only pretty much the same 30.5" diameter as the OEM tire.
Your thoughts on the best/largest size for 16" rim w/o lift or spacers?..
