Anyone run a 9 inch wide wheel with 285s?
They will on 17-in wheels but not on 18 in.
It also varies for manufacture to manufacture but my toyo 285s came on the truck when I bought it with stock wheels and they worked but clearance was paper thin.
Edit sorry I forgot the truck also came with 2 in lift spacers originally as well that may have given it just enough height to clear.
That makes sense.
I was making my statement based on how my 255s on stock wheels align with the UCA. But I was failing to take into account that most 285s are a bit shorter than my tire.
Mirage775
Huntsville, Alabama
Water Meter Tech I
I'm running a 9×17 -12 outset with 285×70 micky Thompson Baja boss tires . Recovered front and rear crash bars and front splash guards. No rubbing issues. Absolutely love the tires smooth quite made a big difference in the ride .
I like those "mud splatter" decals :)
Mirage775
Huntsville, Alabama
Water Meter Tech I
Yes I have RTR 0+ on 285s.
You will need to either replace, cut, modify your bars.
I had a 2" level and 2" spacers on factory sport wheels prior to getting my RTR wheels and Eibach suspension. This gave me an offset of +4 on factory wheels and they had to go.
Edit: Hmm 30+ ? I dunno you might be ok.
Pic from almost 3 years ago and pic from this week. (same tires 285/70/17 Toyo OC2)
I guess I should've found this thread, before ordering my stuff, but anyway, I'll go ahead and ask my question?
Most of yall know, I've been dropped 3" front and 5" rear for almost 2 years, running 20x10 -24 offset, with bars removed and minimal rubbing on inner fender liners.
But now, over the past week, I've returned the Ranger to stock suspension, added a 2.5" lift spacer in the front and an additional 1" block in the rear.
Jack @OFC Ranger , I also ordered RTR wheels, 17x9 0 offset, along with 285/70 all terrains. I'm pretty sure I won't rub anything, but my main question is, I know the 285 is about 2.5" taller than the 265, but for actual height wise, you have to cut that in half, correct? It would be 1.125" taller on the bottom, with the 285 tire? The other 1.125" would be gained on the top of the tire? Needing to know for garage door entry purposes?
