+35 offset 8.5" wide wheel, 12.5" wide tire
Superdannyboy
Hey guys, I'm looking to run 37's so I need to sell my 16" wheels and buy some 17" wheels.
Will a 12.5" wide tire clear the calipers on a 17x8.5 wheel with a +35 offset?
That is the equivalent to a 3/4" spacer on the factory sport wheel.
The tires in particular are ko2 37/12.5r17
I would like to buy the same wheels I have now but in a 17 and I don't want the 0 offset as it swings the tire out wide when turning and the only other option for that wheel is a 17x8.5 +35 offset.
That's approximately 3/4 of an inch pushed out from the stock sport wheel I had on the truck which are a +54 offset.
If you guys are running 33/12.5r17 or 35/12.5r17 on a 17x8.5 +35 offset wheel than that means it will work.
Will it clear the brake calipers? Most likely. Will it clear your suspension assuming you have one of the long travel Baja kits? Thay is the real question
