Android Auto and other forms of Mental Anguish..
LocoEngr
IL
2021 Ranger
Hello,
So I tried using my Android Auto for the first time today. When I first got the truck, every time I plugged the phone in to charge it would tell me Android Auto was available but eventually it stopped doing this.
So, I was at the dealership today and they showed me how to turn AA back on. Once I left I tried to get AA to work and could not. I probably spent an hour trying to figure it out.
I would plug the USB in and I would get a tile for Maps and Android Auto and then maybe 10 to 20 secs later a screen would appear with a black background but it would only stay up for 1 to 3 secs before it disappeared and then the tiles for Maps and AA would disappear. If I pulled the cable out and plugged it back in, the same thing would happen.
Since it looked like the AA screen was trying to come up, I was thinking it was a SYNC 3 problem but after reading this thread, I'm thinking I should buy a new cable tomorrow.
Really the only thing I wanted AA for was Maps and to use my Sirius/XM app. I guess if I can't get it to work its not a big deal but combined with the fact that sometimes using my remote start through FordPass is like gambling, I'm starting to edge towards moving on to something else next time(and I all ready left and came back once).
Jason B
2021 XL STX SE 4x2
machinist
Hello,
I think AA has settings to auto start when hooked up by USB, and there also may be setting on the phone to allow SYNC to access AA. It's been a while since I set it up on my truck and phone.
Can't you use your Sirius account with SYNC without having to use you phone? Or would the truck have to have a separate account with Sirius?
Friday yet?
‘23 Lariat Tremor, Focus ST
Ok, educate me here. Android auto has been working g flawlessly for me. My issue is simply a lack of knowledge on my part. I've searched here and on Google for answers.
So when rolling down the road how do I open the regular Sync screen while Android auto is running? In my case it would/will be running Waze? Multiple times today I wanted to quickly pull up the climate controls screen but could not do so.
Thx!
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Thx!
I'm not used to the new screen yet so there is probably an easier way.
I push the square on the bottom left which brings up the screen with all the blue circles and press the "sync" button which brings me back to the radio/climate control screen. Must be an easier way that I don't know.
VAMike
2019 Ranger Lariat SuperCab
No easier way. Some manufacturers implemented more flexibility, ford does not.
Makes you really wish they hadn't disabled climate control with the steering wheel buttons on the ranger.
SteamiestOyster
Seattle, WA
Aerospace Engineer
Hello,
What you are describing sounds like you need a better cable. USB cables are not all equal. Make sure your cable is USB 2.0 (480 Mbps). Don't get a USB cable that says something like "charging cable only" and make sure it says "USB 2.0" or higher.
Dr_Strangelove
Adam
Henderson, NV
'22 XLT Supercrew 4x4
Art, Design, Photo & Video
Friday here is the procedure. You need to tap the "stack of dots" icon in the lower left hand corner of the screen - this brings you to the Apps menu.
Then you want to find the "Ford" app. (Top Left.) This brings you back to the Sync Screen.
To get back to Android Auto - Tap the Android Auto button on the bottom row of Sync.
While you are in Sync mode - so long as you are connected via Bluetooth on your phone - you won't lose any of your audio from your Android apps while you are doing this.
Cheers!
Thx!
Nellieg
Maryland
2019 ford ranger crew cab
Cheers!
Any reason you chose that beck song...was that a commentary?
BryanJay
Bryan
Northern Alberta
2024 Ranger XLT FX4
Thx!
I don’t know if AA is any different, but with CarPlay hitting the Home button on the steering wheel switches back to Sync.
mtbikernate
NC
2019 Ranger XLT 4x4
with AA, it takes you to the AA menu, same as the dots in the bottom left. You still have to tap the "Ford" app on that screen.
VAMike
Good advice, but mostly useless. There's basically nothing that a buyer can look at to distinguish "good" cables from "bad" cables. Not price, not labeling (they lie, and there's no enforcement). One thing that can help is to buy the shortest possible cable (because physics, you'll have more signal degradation on a long cable than a short cable). If it works with a 6 inch cable then you know it's a cable problem, and you can just keep buying longer cables until you find one that works. (Or, just stick with the 6 inch cable. That's what I did--6 inch cable into a wireless adapter, and cable problems aren't a thing anymore. :) )
Friday yet?
Ok. Got to remember and look for the Ford app.
Thank you.
