Alpharex PRO Review
I tried it, it only turns off the low beams. It keeps the LED strips on during day time on Auto. Which is perfect, no forscan neesed.
Learn something new everyday. Thanks for the reply back, appreciate it
JBro
North Dakota/Idaho
'21 XLT FX4
Army veteran/student
Do you have the DRL module/connection installed?
JBro
North Dakota/Idaho
'21 XLT FX4
Anyone know why my lights will turn off when switched to Auto mode? (PROs, w/drop in LEDs--work great otherwise.)
Synyster06Gates
Austin
Liberty Hill, TX
That's weird. Mine operate perfectly in auto mode. Try turning off the DRL from the truck menu. That turns off the lower voltage operation - I wonder if that's what's messing up some bulbs for people.
JBro
North Dakota/Idaho
'21 XLT FX4
I did, and that didn't seem to have any effect. Is it my choice of LEDs perhaps?
Delirious
Nick
2021 Ranger Tremor
I have Auxitos in the fog lights. The Auxitos were known to fit factory fogs, that's why I used those. Since no one had swapped the PRO halogen bulbs for LEDs, I didn't have any idea what would or would not work but it ended up being a great fit. I just picked a set that looked decent and wasn't too pricey
I have the Auxitos and all my lights and they are awesome. But I love these that you have in there and I so want to go do that but I have to wait until the crypto goes up some more.
Zvedza
'21 Ranger Tremor, '04 SVT Lightning, '16 ZX-10R
Followed this thread for my alpha rexs. Appreciate everyones input in here, really helped navigating through all this much easier.
If only putting in the headlights was as easy.
I used the Aukee H7 110W bulbs someone listed earlier, i did receive one dud one out of 4, but unfortunately couldnt just leave this unfinished, so one of my high beams is the stock halogen bulb.
I was also worried id have issues with them shutting off while driving, as they do seem to produce a lot of heat, but they did not turn off at all while driving for around 40 minutes.
Zvedza
Update
Drivers side is now switching off. Lasted 2 weeks fine, but now around 10 or so minutes till turn off and when i switch it back on itll shut off in a few minutes.
Im gonna try to swap in a different brand LED, the aukee ones ive gotten have been a disappointment.
JBro
North Dakota/Idaho
'21 XLT FX4
Update
By happenstance, i haven't driven more than 10 minutes at a time with mine on, but have the Aukees. Now I'm a little nervous! Keep us updated on which bulbs you go with and your thoughts/opinions/test results!
Zvedza
Ordered these, they seem shorter so hopefully its not right up against the dust cap on the assembly like the Aukee ones are. https://www.amazon.com/gp/product/B091TDCG1L/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Weird thing is that on my way home they didnt shut off, but on my way back to work this AM they shut off again. Not sure what the issue is, same temp going back and forth so it shouldnt be that, maybe the fan isnt turning on some starts or just has simply gone bad.
Just hope i can get my hands behind them good enough to remove and replace them. Drivers side looks like it had enough room, passenger side is a tiny bit tighter, but at least for now that side has no issues. Weird how it seems to be only a drivers side issue
It is dark out and the truck running right? That's what it takes for the lights to come on in Auto.
AdamHarris
Adam
Blue Oval City, TN
Collision Repair Instructor
I posted this in another thread but just a suggestion when you wire up your DRL‘s. Do not modify the fuse box lid with the important seal. Make a cut on the fuse box itself and let the seal come down over the wire. Put a little silicone in there once you have your wire in place. These Alpha Rex alpha black PROS w LEDs are definitely worth the upgrade!
