Alpharex PRO Review
theanswer3
Tampa, FL
2020 Ranger XL
It did it first right when I pulled up to get the headlights aligned, then again leaving and again waiting in the drive-thru. Definitely has me a bit paranoid about driving around at night. Guess I'll spend a good amount of time figuring this out tomorrow. I bought the Pro so I could swap bulbs, but even that looks like it'll be a chore. Everything is just so tight.
Agreed. I'm definitely going to check it out as well. It's kinda weird we both had the issue with driver side low beam. maybe it is a setting in forscan we have to change. also do you have the DRL wired up separately. I currently do not.
CoachJ
Rhett
2021 Ford Ranger Tremor
Teacher/Coach
I do have the DRL wired up.
When LED’s overheat they will shutdown or blink. It’s a protection circuit to keep from burning them out. How’s the airflow around them? Could be lesser brands do this if encased inside assembly
CoachJ
Rhett
Teacher/Coach
Definitely could be the culprit. They're basically against the cap in the housing.
CoachJ
Rhett
Teacher/Coach
Man I don’t know what the issue is…took the dust caps off and turned them on…still took about 5 minutes before the driver’s side turned off.
Flipped them and the problem went away. I was thinking as I was watching them work outside the housing that maybe being wedged in there was making the fan not spin, causing it to overheat?
theanswer3
Tampa, FL
2020 Ranger XL
It shouldn't be different then the ones the OP listed. His were exactly the same design wise just a lower wattage.
theanswer3
Tampa, FL
2020 Ranger XL
That's not out of the question still. Higher wattage does mean more heat.
True, but in this case I don't think it would be enough to make a major difference. I have the exact same setup and am not having the issue every time they come on. For me it happened one time. Also doesn't happen to the passenger side for either of us. Only driver lowbeam. If it was a heat issue I would think it would happen to both sides since dustcap and distance to the fan is exactly the same. I would like to test out the bigger dust caps to see if it does make a difference for overall cooling.
TeaWrecks
Vincent
Canada
2021 Ranger Tremor XLT
Passenger side has the air intake right above it. Haven't taken delivery of mine yet but is there anything that gets warm on the driver side?
Is outside air temperature high right now too where you guys are at?
CoachJ
Rhett
Teacher/Coach
Well it lasted longer this time, but it is for sure a driver's side only thing...it went out again after maybe 10 minutes or so. Turned it off and back on and it worked. Waited another 10 mins or so and off again. This is after flipping sides and still with no dust caps at all, so the extended ones I ordered aren't needed. I guess tomorrow it's back to the halogen bulbs I go, at least for now.
Heat shouldn't be an issue; this has got to be the coolest July I've ever experienced here in Texas - while the rest of the country apparently is burning up.
Synyster06Gates
Austin
Liberty Hill, TX
Interesting - so it didn't follow the bulb? Just stayed on the driver side?
