56k diff fluid change today
21rangerCactus
Self employed
No pics.. Just wanted to say at 56k the diff fluid flowed out a clear gold color. The drain plug did have some fine metal shavings stuck to it but nothing out the ordinary. Didn't surprise methat it was still good, to be honest. I bet it could have made 100k easy.
Tremorky
Scott
Kentucky
2021 Lariat Tremor
CAD Designer
No pics.. Just wanted to say at 56k the diff fluid flowed out a clear gold color. The drain plug did have some metal shavings but nothing out the ordinary. Didn't surprise me to be honest. I bet it could have made 100k easy.
Changed mine recently at 24k. Looked good and only a sludgy gob of grease on the plug
db_tanker
Darrell
Process Professional
Do you guys have the E-locker or LSD?
Peter949
Peter
Irvine, CA
2024 Ranger Raptor
I'm thinking of doing a transmission fluid change soon around 70k. I'm ignorant about the differential. I have a 2wd. What do the more informed recommend?
BS67
Brian
Nebraska
2022 Ranger XLT
For the low cost I'd change it!
21rangerCactus
Self employed
Diff fluid isn't expensive. If you have a drain plug that makes it really easy. If you feel like doing it then go for it. I'd say it's not something urgent.
bill_AUS
Billy
Victoria, Australia
2020.75 Ranger Raptor, 2013 Ranger XLT spacecab
Vehicle fleet engineer
Ranger diffs are pretty good, it's the transfer cases that are harder on their oil (in the 4x4s that is). Changing the transfer case oil at semi regular intervals is a good idea for those not in a 2WD.
Cabose-1
Eli
Student
You will get a different answer from each of us.
If its a mall crawler, youll be fine, off road or work, depends on how hard you run it. I have a fx2 tow and stuff so ill do it before the scheduled maintenance, same as tranny fluid. I dont even know what that number is lol, 29k on my odo and only 15months of ownership with this ranger
Langwilliams
Langley
Lorain, Ohio
I had a 4wd with the rear locker an changed the fluid at 20K an I was surprised how dirty the rear was. The front looked fresh. I never used 4wd much but I used to use the locker to do some hard launches after I got the tune.
Mis using the Locker is probably the main cause to the fluid looking like such. Keep that up and you can expect to see the rear end grenade on you.
TomSim
tom
toronto
What kind of diff fluid did you use and how much did you need?
